Subaru Legacy Forums
-   Wheels/Tires (http://legacygt.com/forums/forumdisplay.php?f=43)
-   -   Wheel offset and tire combo for RWD LGT (http://legacygt.com/forums/showthread.php?t=197021)
btlegacy 11-26-2012 12:28 PM
My 05 Legacy GT is now RWD. I have read some of the stickies and looked at different offsets and such and wanted to hear some recommendations on wheels and offset sizes. Here are the specs I am trying to meet:
Size: 17" or 18"
Front Width: 225-245
Rear Width: 265-295
Clears Brembos
5x100
My goal is to be able to run a wide tire in the rear that is matched to a wheel that will have a good contact patch. I will roll the fenders as needed but would like to avoid pulling the rear quarter panels
Drift Motion 11-26-2012 01:16 PM
you'll need to pull the rear fenders for 265+ tires to fit
245s on a 9 is very close already for the rear, 255s will fit with some massaging on the quarter panels
235s or 245s on the front is easy with just a simple roll
btlegacy 11-26-2012 02:48 PM
I may try to go for some 255s and massaging. What kinds of offset do you recommend?
Drift Motion 11-26-2012 03:41 PM
9 +38
you can probably go a few mm higher on the ET, but I'm not sure how much clearance there is with coils
Windy Road 11-26-2012 06:26 PM
RWD you don't say
btlegacy 11-26-2012 07:48 PM
Yes sir, you can see it here http://legacygt.com/forums/showthrea...q4-191260.html
btlegacy 02-25-2013 09:57 PM
I am going to go ahead and modify the rear quarters. I would prefer to run 17s and be at a 275 width in the rear. Something like 1 17x9.5 maybe. Just not sure on offset
btlegacy 04-10-2013 11:54 AM
Things have changed a bit since my initial posting as I have gone to 5x114.3 hubs to match my rear end and am also looking to go to an 18in wheel so clear brakes that I am going to run.
Drift Motion 04-10-2013 12:02 PM
details on how did you swap to 5x114.3? pretty please?
is it in your build thread?
btlegacy 04-10-2013 12:08 PM
Some of the info is in the build thread but basically I modified the subframe to run a
Infiniti Q45 R200 rear differential
Infiniti J30 axles
300ZX NA Hubs and Bearing Modules
Brakes will be a hybrid of 350z rear rotors and Brembo Calipers
Drift Motion 04-10-2013 12:14 PM
oh... nvm then
I'm converting to either Z32 or S14 hubs too...just not on the Legacy...haha
