Subaru Legacy Forums
-   Wheels/Tires (http://legacygt.com/forums/forumdisplay.php?f=43)
-   -   winter tire psi?? (http://legacygt.com/forums/showthread.php?t=196731)
stuck686 11-21-2012 09:22 AM
winter tire psi??
i know the stock psi but i have Michelin Xice winters on and they are max psi of 50. It looks a bit softer than when it did when discount tire mounted them on. I check it and its currently 45 front 43 rears. What should i pump it up to??
outahere 11-21-2012 09:57 AM
You need to take it down, not up. No more than 38F and 36R. Lower pressures favor better snow traction. What the tires look like (hard or soft) is not relevant.
krzyss 11-21-2012 11:51 AM
Where are you checking temperature (garage/outside)? What is ambient temperature?
Krzys
stuck686 11-21-2012 11:57 AM
check it outside before i drove it. its been 40 but will be lower soon
krzyss 11-21-2012 12:13 PM
The rule of thumb is 1 psi drop for each 10F if I am not mistaken so if you want to be ready for 0F you need to add 4 psi to pressures on the placard (when measuring at 40F).
Krzys
stuck686 11-21-2012 12:55 PM
yea but i dont know what it started at
krzyss 11-21-2012 02:40 PM
Soo, what size tire do you have? I think OE size 215/45R17 calls for 33/35.
I ran 225/45R17 at 36.5/38.5 - routhly 10% higher than placard.
Krzys
TheOneDoubleN 11-21-2012 03:11 PM
Where's turbodog when you need him?
iNVAR 11-21-2012 04:52 PM
Krzys
35 F, 33 R for stock 215/45 17 is indeed what's called for.
