Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Valve cover removal (http://legacygt.com/forums/showthread.php?t=196613)
hukne001 11-19-2012 10:28 AM
Valve cover removal
What I know: I need to remove my passenger side valve cover due to it dripping oil onto the uppipe and creating a nasty burning smell.
Don't know: If the leak is due to a cracked valve cover or just a bad gasket.
Need to know: What are some tips for those that have removed their valve cover and is there any gaskets or seals that will need to be replaced in removal of valve cover and other items during this process?
Thanks
Nrw 11-19-2012 10:31 AM
most likely bad gasket
search search search
this was just covered again last week.
hukne001 11-19-2012 10:37 AM
I did search but didn't find anything. I'll try look again
Nrw 11-19-2012 10:40 AM
https://www.google.com/search?q=valv...w=1098&bih=450
Lucid 11-19-2012 10:44 AM
I don't think there's a walkthrough for the valve cover gaskets, but this thread has some good tips:
http://legacygt.com/forums/showthread.php?t=179627
It's not too tough. On my OB I did the passenger side, in place, without running into any complications. On the 2.5i, both sides were leaking, and the timing belt needed done so we just pulled the engine.
Good luck.
hukne001 11-19-2012 11:04 AM
See when I do my searches I type it in on the forum search and never seem to get relevant anything.
Thanks lucid
Max Capacity 11-19-2012 12:05 PM
Yea, most of us know the search function, sucks.
mustangendsley 11-19-2012 12:33 PM
it is a pain in the ace job. bolts are hard to get to in the back. gasket always falls off. i had a hard time with mine. a subaru mech had a hard time doing it also. Took him 3 times.
Aracheon 11-19-2012 10:39 PM
I took a stab at the RH one with the engine in the car - the gasket ended up folding up inside the cover upon reinstallation, and as you can imagine, made a hell of a mess all over the floor.
Since my clutch was making a little bit of noise anyway and I feared having to install a TSK3, I just yanked the engine out and did both rocker cover gaskets at the same time. Hell of a lot easier with the engine out of the car. (Though I've been told you can raise the engine up a few inches to give the space you need to do the covers.)
But since it took me the same amount of time to do the passenger side cover gasket with the engine in the car as the process of pulling the engine and reinstalling it, I'm not sure which route I'd take if I had to do it again. Would depend on how much space I had, I suppose.
