Subaru Legacy Forums
-   Tuning (http://legacygt.com/forums/forumdisplay.php?f=84)
-   -   wideband for logging (http://legacygt.com/forums/showthread.php?t=196531)
haycock 11-17-2012 03:29 PM
I'm going to be doing some logging and want to hook up my wide band to the laptop.
I bought a plx wb and got the cable to go from the module to laptop so if i plug it in to the laptop will ecuflash automatically read it? I'v searched with no answers.
Thanks,
Bryan
bnguyenbb6 11-17-2012 08:51 PM
Use Ecuflsh for writing to the ecu. Use RomRaider for logging. There is a plug in for plx I believe.
joeleodee 11-18-2012 07:34 AM
Yes, what he said.
Moving forward, once romraider is reading data, you will have to click on plugins and select your respective wideband sensor and switch the com port to which one on your laptop you have it plugged in to. Then go to the 'external sensors' tab and check the box that corresponds to your sensor. After that, it should read.
Check this thread for reference to your wideband.
http://www.romraider.com/forum/viewt...3e429fa472e55c
haycock 11-18-2012 08:15 AM
Thanks for the replies. I think i got it.
