My 05' RGP Legacy 2.5GT (5EAT) Build Thread
So long story short my shortblock has the metal shavings thing which my subaru guy verified, so I'm now waiting for a 2010 STi shortblock which I believe has the nitrated crank.
I will take this oppertunity to upgrade my turbo with bnr's modded VF40 with 18G turbine wheel and TD05H compressor wheel - this car will be my daily driver so I didn't want to get all crazy.. http://i88.photobucket.com/albums/k1...s/th_image.jpg |
Sounds great. Might want to also think about beefing up the transmission a bit--external cooler and VB mod from climberD. Also, are you doing fuel mods as well with the 18g (injectors and fuel pump)? If not, you may want to stay a bit smaller with a 16g or VF52. Also replace your stock up pipe with a catless option (aftermarket or stock sti from 02+ will work just fine). And a downpipe, bellmouth design.
Hopefully you've already though of all of this or you just added about $2k to your build :) And maybe new pistons...the stock ones suck. |
I would at least put a pump in, you will run out of fuel tuning that turbo.
If you ordered a new EJ257 from the dealer, I was told they get whatever is the latest the factory is making. So if you ordered a 2010 EJ257, your going to get a 2012 EJ257. Which has the same crank.
If you do decide to get injectors and go top feed I would recommend ID1000's. Have had really good luck with those injectors in my car, my tuners 500hp Taurus SHO and his 400hp STi among other cars. I'm one of the few not on E85 right now. Those injectors will definitely give you room to grow.
Whoa man yours has an awesome shine! Looks spotless
Who and what are you using for tuning?
My friend actually tunes a lot of the local subies around. Open source. This is his SHO on ID's site. http://idcarofthemonth.blogspot.com/...amics-car.html
If your goal is to get to 300-330 awhp, I really think you're going to want to drop in some pistons while your at it and your transmission will thank you for the F1 Valve Body.
It's possible that you'll be just fine without doing either, but it's also possible that you'll end up breaking something at those power levels. Just weigh the up front costs vs the chance of breakage at an inconvenient time and decide on your own risk level. |
| All times are GMT -6. The time now is 05:30 AM. |
