Subaru Legacy Forums
-   Performance/Dyno Numbers/Track Times (http://legacygt.com/forums/forumdisplay.php?f=119)
-   -   07 lgt stage two Mustang dyno (http://legacygt.com/forums/showthread.php?t=196474)
chaz517 11-16-2012 10:09 AM
Tuned by ecs performance 255whp and 284wtq
2007 lgt manual
Mustang dyno
http://www.eastcoastswappers.com/mai...rgb1=000000255
http://www.eastcoastswappers.com/mai...php?runid1=461
What u guys think... Posted this from my phone so I'm sorry about the format
lee07 11-16-2012 10:23 AM
Looks just like mine when I was stg2, same curves, just you make more power in the high range - redline and mine made more in the low and mid range but fell after 5700rpm but it looks good.
6 months from now you'll probably be stg3 or at least thinking about it
chaz517 11-16-2012 10:27 AM
Sweet thanks man. Def pulls harder than I expected. I'm already thinking about stage 3, so sad haha. It's like having the flu. Not sure if it be worth it to go w tmic and then re tune or just save up for turbo and tmic and then re tune. What do u think about my boost.? Thought 19 psi was kinda high for the stock turbo. Unless the previous owner switched it and I can't tell haha
Drift Motion 11-16-2012 11:40 AM
save up for all supporting mods for stage 3 build, and re-tune it at once
someone said this: stage 2 is just a placeholder for future stage 3 build
liljonson 11-16-2012 12:10 PM
Im at 20psi stock turbo and its fine. Id be more worried about your stock intercooler. Definitely should think about jb welding that junk
wurkenman 11-16-2012 06:39 PM
ALWAYS want more power. I am at just under 330 and am already planning on a new turbo and injectors. :icon_razz
chaz517 11-17-2012 08:13 AM
Def gotta do the jb weld trick. Wish I had the funds to go stage 3 now
lee07 11-17-2012 09:21 AM
Stage 2 is all you will ever need on the street.
More is nice but you will never use all those power on the street.
Just wait until you have everything for a stg 3 build and tune it then unless you are sure that just a little bit more from a bigger intercooler is the last and final upgrade you will ever do.
My stock intercooler was fine at I think 17-18psi but then I never really drove it all that hard.
Right now this is all the power you will ever need on the street unless you are into drag racing
.:Catalyst:. 11-18-2012 11:32 AM
Mine separated at 17.5psi - highly recommend the "Bulletproof kit" if you are running stage 2 power levels and plan to keep the OEM TMIC, (which is efficient but weak where the core attaches to the plastic end tanks), and I think it's a better solution than JBWeld.
Moddiction 02-06-2013 01:14 PM
Need maybe. Want definitely not haha. 300 ish whp feels very normal after a little time spent getting used to it.
I know in my other car I am currently at 410whp in a 2800 lb car and feels almost like stock to me now.
