Subaru Legacy Forums
-   Warranty Issues & Problems (http://legacygt.com/forums/forumdisplay.php?f=48)
-   -   Normal price range for head gasket replacement? (http://legacygt.com/forums/showthread.php?t=196473)
MJ in PA 11-16-2012 11:07 AM
Subaru continues to disappoint me. I probably would've saved a whole lot of headache by buying a Honda! The latest hit is that while spending nearly $400 today on routine maintenance stuff (like battery and belts - no complaint there though, expected expense) I learned that I've got a head gasket leak which means that according to the dealer I've got a looming $2300+ repair in the near future. I've already had to spend money replacing bad wheel bearings and a few other things that shouldn't happen pre-100k miles. (I'm at about 79k now.) I was already planning on new tires and new front brake pads and rotors in the next few months - now I can add the head gasket replacement to that. Grrr...
So, is the dealer quote way out of whack? Seems high to me.
AZP Installs 11-16-2012 12:24 PM
Not terribly high, but depends on what it includes. We could diag it for you and see if ou actually need it. A bit of a hike to us but may be worth it.
-Mike Paisan
http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/14...8/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
Max Capacity 11-16-2012 01:46 PM
So how do you know a HG is going ?
Does the car have a miss when your driving it ?
Is there a lot of white smoke behind you all the time ?
Is there coolant or oil leaking into the ground ?
Don't believe everything the Stealership tells you.
Supposedly Subaru fixed the HG problem, back about the year 2000'.
MJ in PA 11-16-2012 01:50 PM
None of the above. They told me to keep an eye on fluid levels and look for any burning smell. Looking at paperwork, note says "both gaskets are leaking..oil leaking on exhaust on right side". They gave it a "yellow" on their green/yellow/red checklist.
PeterJMC 11-16-2012 01:51 PM
How many miles do you put on the car in a year?
I'd be interested to know how they determined that you have a HG leak, can you provide us any additional info in why the suspect it?
100k is around the corner, might as well have the timing belt done while they are doing the HG.
Max Capacity 11-16-2012 01:52 PM
More then likely its the valvecover gasket that is leaking. These cars are known for that.
It's a lot less money.
How close are yout o Mike at AZPinstalls.com, his guy's could help you and take good care of you.
AZP Installs 11-16-2012 01:53 PM
That sounds more like valve cover gaskets, which cost considerably less than headgaskets.
-Mike Paisan
MJ in PA 11-16-2012 01:56 PM
Thanks...my username is out of date, btw, I'm actually down in Williamsburg, VA...doing my MBA at William & Mary. My parents live up in Hazlet, NJ though which brings me back up that way on occasion.
Max Capacity 11-16-2012 01:58 PM
WHen your home for the holidays, make it a point to stop by AZP.
AZP Installs 11-16-2012 09:01 PM
Hazlet is close by us, about 15 min and we can eval it for you.
-Mike Paisan
MJ in PA 11-18-2012 11:13 AM
Thanks, will do!
