Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   ATF fluid: What came standard? What do you recommend? (http://legacygt.com/forums/showthread.php?t=196465)
Adoniram 11-16-2012 07:51 AM
I'm about to do a full 60k service on my LGT and wanted to know what you guys have been using in your 5EATs, and what came standard?
Also, is 75w90 Redline ok to use in both the front and rear diff? Where is the fill/drain for the front?
Thanks!
BarManBean 11-16-2012 08:01 AM
Subaru ATF-HP fluid for the transmission. I believe the redline is fine, I used Motul Gear 300 last time I did mine.
The drain for the front diff is pretty obvious when you're under the car--it says "Diff" on it, lol. Towards the front / passenger side compared to the transmission drain. Fill it through the dip stick. Same with transmission.
Adoniram 11-16-2012 08:04 AM
Awesome, thanks. Is 1qt enough for each?
BarManBean 11-16-2012 08:06 AM
you'll need 3-5 qts to drain / fill the ATF.
I believe my front diff took 1.4L of new fluid. Rear is maybe .7/.8L.
Adoniram 11-16-2012 08:22 AM
There's a lot of ATFs out there... Anyone recommend anything? Royal purple?
laff79 11-16-2012 08:26 AM
BarMan answered the question nicely.
stuck686 11-16-2012 08:53 AM
i am putting subaru extra S in my tranny when i do it
BarManBean 11-16-2012 08:56 AM
Thanks for that contribution. OP, please don't put manual transmission fluid in your automatic transmission.
stuck686: ATF stands for AUTOMATIC transmission fluid, which extra S is not. Probably a good call putting it in your 5MT though, seems to work great in that application.
Adoniram 11-16-2012 11:08 AM
Ok, ya I just want to order online so I'll try to search Subaru's site. Im trying to order everything via Amazon, but can't find Subaru ATF on there. I see lots of this though:
BarManBean 11-16-2012 01:56 PM
I just picked up the ATF HP from the dealer, their price was actually decent at 7.50/qt. I think FredBeans has the same price, but obviously you'd have to pay shipping.
BarManBean 11-16-2012 01:57 PM
Don't forget to grab a crush washer for the transmission / diff drain plugs also.
captainobvious 11-16-2012 02:04 PM
I run Amsoil ATF and Amsoil 75w90 in my LGT
BarManBean 11-16-2012 02:04 PM
Did you do a flush with Amsoil, or just a drain/fill?
Adoniram 11-16-2012 02:26 PM
Good call. You wouldn't happen to know what size they are?
I would go to a Subaru dealer, but there's isn't one anywhere nearby... I'd rather save the 1.5-2 hours and do something else with my life :rolleyes: Plus I get free shipping with Amazon, so it's highly convenient.
I think I'll try Redline ATF. I can't imagine there will be any problems, especially since they claim to support this specific vehicle with that fluid.
BarManBean 11-16-2012 09:27 PM
Sounds like you didn't need to ask what fluid you should use in the first place since you are pretty set on the redline, lol.
You could probably just give fred beans a call and get everything you need directly from them for a great price.
