Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Top Feed Injector Install (http://legacygt.com/forums/showthread.php?t=196429)
LouzGT 11-15-2012 04:09 PM
Would it be easier to install my injectors by removing the intake manifold first? Just asking because i am putting in spacers ne way so i would then do both at the same time. Lmk thanks.
mikeyvt 11-15-2012 07:17 PM
Have you already put in the topfeed tgvs already?
LouzGT 11-16-2012 12:07 AM
i have an 08 it comes with top feed TGVs
Strizzy 11-16-2012 08:00 AM
Why are you doing spacers?
LouzGT 11-17-2012 06:41 PM
I mean i figure i would install the phenolic spacers since its not expensive and would be going in there anyway and help keep the temp down. Lmk what you think
ibr_adam09 11-17-2012 09:05 PM
The plastic manifold is enough to disburse heat. Spacers are more for the sti/ older wrx's since they use metal manifolds. It's up to you, other wise. Save the $60.
Mill 11-18-2012 07:10 PM
+1. Save your money. Maybe look into deleting the TGVs if anything if you are already going to take everyting apart.
mumblinaviator 11-18-2012 07:24 PM
To answer your Question, yes, go ahead and take the manifold off since you have a reason to do so anyway. It's not necessary to completely remove it for the injector install, but based on my experience, it was easier since the manifold was loose and able to be lifted.
LouzGT 11-18-2012 11:55 PM
Thanks everyone for the input!
