Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Water under the passenger seat (http://legacygt.com/forums/showthread.php?t=196416)
700watts 11-15-2012 12:32 PM
I'm stumped on this one, I checked the windows, sun roof, and doors. Iím thinking itís the A/C but under the glove box is dry. Anyone else have ideas ?
:confused:
adreyna 11-15-2012 12:46 PM
Somebody spilled water?
700watts 11-15-2012 12:50 PM
funny, I failed to do some searching .....looks like everyone has this prob..but I'm not thinkings its the A/C drain. Only one way to find out
700watts 11-15-2012 12:55 PM
Mods...close thread
.blackgt. 11-15-2012 01:49 PM
Don't close it, update us with what you did to fix the problem so people can stumble upon this thread and read your outcome.
700watts 11-15-2012 05:13 PM
aight..scatch that, stay tunned
thefultonhow 11-15-2012 05:42 PM
:orly:
It's probably that you went so fast that one of your passengers wet herself.
700watts 11-15-2012 05:46 PM
Originally Posted by thefultonhow (Post 4160700)
:orly:
That is possible ..:cool:
LGT612 11-16-2012 02:57 AM
Sounds like an evap core leak. Underneath the vehicle somewhere on the firewall should be a length of small diameter tubing. Most are two to three inches long and are bent 90* downward, but I have seen very long ones in the past as well. This is the drain from the evaporator core used by your A/C system. Occasionally these drains get plugged and the condensation has nowhere else to go. If you have access to compressed air, it is easy to use a blowgun and shoot a small burst of air into the drain to clear the obstruction. Otherwise, careful use of a length of mechanics wire will work as well.
I'm always surprised at how much water comes out of these things. Last summer I had a Mitsubishi in the shop and I bet 3 gallons came out
700watts 11-27-2012 12:20 PM
case solved, It's is the A/C or a clogged drain.....thought it was somthing else...after cleaning, about 10g of water came pooring out
