North Shore or nearby MA for a hand with SS install?
Does anybody from MA (preferably the North Shore or not too far from it) have a pair of snap ring pliers? Apparently the tool is recommended for use to install the Kartboy SS when you have to remove the ring, and I don't have a pair. I don't really want to invest in them because it wouldn't be worthwhile at this point for me. Install seems straightforward enough, and I also have to put in the new shortened shift boot from Redline while I'm at it. It would just be nice if anybody had experience/time and had those pliers to offer a hand. I've read the instructions.
Appreciate it! Andrew |
i used curled needle nose ones and it prob took a little longer but it worked. if you have a pair of small needle nose you can do it. The snap ring is not that small just in an awkward spot.
otherwise, you can borrow the pliers, i'll know who you are if you don't bring them back. :lol: i did my cobb short throw shifter and bushings using ramps. the rear bushing was a pain in the ass. very tedious work. but i'm a stubborn bastard. |
ok man, let me know. trust me when i tell you the pliers are the least of your worries. :lol:
ETA: do you have jack stands or ramps? |
I have 2 jack stands but I'm not installing any bushings, just an SS kit. I think it would work out best if I borrowed the pliers since I have an odd schedule. The SS came today but will be working on it next week. Will keep in touch, thanks again.
What is your schedule and do you need a warm garage?
Gee, that's awfully nice of you :)
I'm not free all day Mondays thru Wednesdays, nor Thursday mornings. I don't quite need garage to put in a SS, but I'm trying to clean mine out so I can jack up the car and remove/refinish my wheels! |
well I am obviously northshore too so if you do need warm garage or help, I have tools etc too and around at weekends. offer is there.
Nice! Have either of you any experience with installing Redline shifter/parking brake boots?
I'm available from now forward.
hey, i keep forgetting to check in here. -as i don't own a legacy no' mo' LOL.
try the e-mail function if you want to borrow my ramps since you have the pliers. i have other tools too. not sure about the shift boot on the Leggy because i recall mine (it was a 2012 premium) having the electronic parking brake. if the 07 is anything like the WRX, it's easy to remove. -lastly, anyone can correct me if i'm wrong, but changing the shifter alone is not worth it. YMMV. the bushings make it THAT much better. i did my bushings first because i wanted to make sure i could finish the job. anywho, lemme know. PM, post, but e-mail works best. LOL i'll double check that i can get e-mail notices of PM's. |
i'll get an e-mail if i get a PM. holla if you need to.
good luck, -chet |
If you have sigmafour help you then I can lend him the snapring plyers for you guys to use ;o)
He works right around the corner and I know he'll bring em back! :lol: |
| All times are GMT -6. The time now is 09:43 PM. |
