Car stalls with clutch in while in gear at idle
05 LGT 5 speed
The car stalls, but only in specific instance: When I'm coming to a stop, I push in the clutch and keep the car in gear while coming to a stop - the rpm's dip WAY down; sometimes the car stalls, sometimes it catches itself. Started happening last week and got worst this week. Today I stalled on the highway while i pushed the clutch in. Had to restart the car while it was rolling.. I tried looking for a vacuum leaks by visual but dont see anything suspicious.. Any idea of what it could be? :confused: |
On CEL...
I'm thinking your a few day's away from one. 05's are known for idle issues cause by leaking o-rings when it's cold out. Since I replaced the o-rings between the intake manifold and TGV's I have not had a issue. When you see the new o-rings next to the old one's, you'll understand the problem. $20.00 in parts, a few hours labor to lift the intake a bit and replace them. Does the car run well other wise ? |
The car runs well otherwise. I do have a air sucking noise when I'm accelerating. Kind of sounds like an aftermarket intake but I'm on a regular stock panel filter. I've taken the intercooler off before which is quite simple but Is there a write-up on taking off the intake manifold and replacing the o-rings? |
Have you taken off the TMIC to check the blue T under it? Also, lemme know if you want to stop by my place and I'll plug my laptop in and see what I can find.
A buddy and I did mine in a couple hours. |
Okay, keep us posted, lemme know if you need a hand with anything. :)
Hopefully the MAF cleaning solved the problem so i dont have to tackle this Intake Manifold O-ring job |
You will need to do the o-rings sooner or later living in a cold climate. That's just my opinion.
I be honest, it's worse then it looks. I could get the manifold up may be a inch on one side then do the other then bolt it back down. Oh make sure you tighten the fuel line clamps while your in there if you can. |
That's why I did the engine R&R in May of this year. No garage.
BAD NEWS GUYS
The problem came back tonight. 5 mins. into the drive on highway in traffic. It started idle dipping again when I have the clutch in. :mad: What's even worst now is that I have this loud whirring sound(kind of like air leak/air circulation in the engine bay) and every time I push the clutch in the sound changes to a more muffled air leak. Couldn't pin point exactly what it was in the dark. Max Capacity, did you have that whirring air noise when you had the intake manifold gasket problems? |
Do these vehicles have an Idle Air Control valve? If so, check that.
Noise could be the TOB. Is it the orginal ?
I don't remember any air leak type noise. I do remember it stalling when it was cold out from time to time. I recall driving 30 minutes on the back raods, stopping for gas then it would stall a few minutes later sitting in traffic. I was on the way to VT for the weekend to ski. It had stalled a few times before, but nothing constant. I think shortly after I got the deraded P0011 and P0021 I think, the death codes for the turbo, while in CC at 65mph on the highwway. Had a trusted mechanic check it out. He said they remove the banjo filter before the turbo to help that code. CEL never came back, the turbo began to whine under boost, lasted another 1000 miles. during that 1000 miles the read diff went. most of that was during Jan/Feb 2011. When the diff went I found the 09 Spec B for sale that evening on here, bought it a week later. Parked the wagon till warm weather, it spent 5 months that year up on jack stands. During May I replaced the o-rings, while I pulled the and had tranny rebuilt, R&R the rear diff, finally got it back on the road late July, couple weeks later I R&R the turbo with a VF52. The idle issue never returned. I lot of us have hed to replace the o-rings in the 05's. While your in there, zip tie all the vacuum lines you see. |
| All times are GMT -6. The time now is 08:19 AM. |
