Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Timing belt @ 170k (http://legacygt.com/forums/showthread.php?t=196402)
Chappy5107 11-15-2012 05:45 AM
Timing belt @ 170k
looking to go with the Gates system complete with water pump and tensioners... but the shop i use that strictly only does Subaru's has a couple failures with the tensioners, has any one else heard of this? I got about few more thousand to go before I get to that point, but just looking for some input. thanks
Max Capacity 11-15-2012 07:16 AM
Most of us use the gates kit. You will find problems with any thing if you look hard enough.
I used a Gates kit on my new short block.
The first time I used a Dayco belt and pulleys I got from Advance Auto Parts. It's all good.
Chappy5107 11-15-2012 09:19 AM
thanks for the reply max, i am a firm believer in Gates, and always have been. I appreciate your input.
AZP Installs 11-15-2012 09:20 AM
We use exclusively Gates kits here and haven't had any failure issues at all.
-Adam F
http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/14...8/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
seabass07 11-15-2012 09:20 AM
Maybe they just want you to buy oem because it's twice the cost.
mwiener2 11-15-2012 09:22 AM
I hope you're talking about changing your belt for the second time. Gates Good.
Chappy5107 11-15-2012 09:41 AM
hahaha yes 2nd service first one was done @ subaru dealer, all they can tell me is that they changed the belt. cause I am 2nd owner, but I am going to do everything this time.
Max Capacity 11-15-2012 10:10 AM
I believe Gates makes the OEM belt. So I've heard on the internet.
Borf 11-15-2012 12:38 PM
-Adam F
Just to let you know I'm coming to you when I get my timing belt done, which will probably be pretty soon. I'm at 97,000 miles right now.
sactojesse 11-15-2012 12:46 PM
The timing belt replacement interval is 105,000 miles, so 170k is early for a 2nd time.
heleu 11-15-2012 02:48 PM
I just had the gates timing belt kit put in 5K ago - no problems.
paintpollz 11-15-2012 02:53 PM
everything is true on the internet:);)
Chappy5107 11-15-2012 04:50 PM
Rather be safe than sorry. Never know when that little piece of rubber might snap
AZP Installs 11-15-2012 06:59 PM
Yeah but he doesn't know if it was just the belt or the whole thing. Generally the belt doesn't snap, it's the tensioner that goes on you.
-Mike Paisan
AZP Installs 11-15-2012 07:00 PM
Thanks. We'll be here whenever you are ready!
-Mike Paisan
