More stupid Questions.
Need to know if any parts out of a 98 forester will fit in a 95 Legacy.
Like the seats, dash stearing colum. |
subaru emblems :lol:
both use the same snogwheel
axles
wheels with smaller than forester tires struts wheel hubs / knuckles rear brakes front brakes if you use 15" wheels or larger engine auto trans if you use the matching rear diff maybe the front part of the drive shaft, maybe all, if both have the same trans auto vs. manual. front seats may swap alternator power steering pump steering rack cats, probably will work if not an exact match, the o2 sensor may have slightly different locations brake master cylinder if both have ABS AC compressor maybe, they used 2 different ones so it is 50/50 seat belts probably steering wheels probably the ''clock spring'' and the turn signal & wiper stalks, but this is just a guess based on how subaru does things ignition key switch door lock cylinders maybe window motors, but they almost never fail radio maf EGR valve IAC maybe battery washer fluid tank if both are wagons fuses tail light bulbs head light bulbs, not the housings maybe a few more things |
There are no stupid questions, only stupid people.
What about the dash, will it fit and the legacy is a sedan.
no
| All times are GMT -6. The time now is 12:33 PM. |
