Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Heated Seat Mod? (http://legacygt.com/forums/showthread.php?t=196345)
D_Sp8s 11-13-2012 08:46 PM
Heated Seat Mod?
My butt portion of the drivers seat heater doesn't work. I was looking into fixing it and was wondering if anyone has modded theirs so that they have a separate switch for the butt portion. That way I could control both sections, back and butt, separately.
BTW, I'm a mechanical engineer and know only the basics about electrical systems.
Anyone done it? Any ideas to make it happen?
MNRZR 11-14-2012 08:43 AM
I can't really help with isolating the seat from the back with switches, but have you seen this walk-through to possibly fix the seat portion?
Fix Your Heated Seat
stuck686 11-14-2012 08:48 AM
i dont think my butt portion works either
laff79 11-14-2012 08:59 AM
mine doesn't either but there's NO way I'm trying that walkthrough. My ass can warm up the old-fashioned way
racso_dor 11-14-2012 09:13 AM
x 2
mitskip 11-14-2012 10:23 AM
If you read that whole thread some guys were also just reaching in and tugging the heat element out enough to re solder the wire. Sounds like the route I will be trying.
bluesuby 11-14-2012 11:18 AM
I have a question from another angle: Neither front seat heater is working. I get illumination at the two switches, so there must be power there. Is there a relay somewhere which sends the heavy duty current to those toaster grids? Seems like there must be a problem other than broken wiring. I don't think anyone has sat in that passenger seat for more than 5000 miles!
Stubeck 11-14-2012 01:48 PM
The butt portion on the drivers side of our Outback doesn't work...but all the other sections work. Its so annoying, guess we'll be doing the mod to fix that.
