Fog lights on 2013 2.5i advice
Fellas:
I have a base 2013 2.5i. I can buy the Subaru fog lights and have installed for a total of $535 BUT, and it is a big BUT, the switch will not be on the "turn signal" handle where the light switch is located. It will be a toggle switch installed elsewhere. Has anyone had this done, and, if so, will you please post a picture. And, if anyone has any suggestions for aftermarket fog lights for the 2013, I would love to know. Cheers! |
I don't think I have ever seen a vehicle with a stalk-mounted fog light switch. Those stalks do so much already, the fog light switch is always located somewhere else (usually on the upper dash, to the left of the steering column.)
I looked at the 2.5i limited and the fog light switch is in fact on that "stalk" as you call it. I don't know what to call it.
The dealer said the switch for the 2.5i base will be a toggle that comes with the "Subaru" kit. They will not be running a wire through the steering column even though the "limited" is done that way. |
Interesting. I can see why they wouldn't add it to the stalk, as that would be a huge PITA, but I'm intrigued as to the fact that the fog light controls are there to begin with. I stand corrected!
It just makes things convenient.
BOARD...my question still stands... I have a base 2013 2.5i. I can buy the Subaru fog lights and have installed for a total of $535 BUT, and it is a big BUT, the switch will not be on the "turn signal" handle where the light switch is located. It will be a toggle switch installed elsewhere. Has anyone had this done, and, if so, will you please post a picture. And, if anyone has any suggestions for aftermarket fog lights for the 2013, I would love to know. |
I too got the 2013 6MT base Legacy. I did order with the OEM fogs and the dealer installed it. The fogs button is beside, same area, the mirror switch. In fact they took the one on my car off and replaced it with another that has the fog buttons. Here is a link that looks the same as mine, http://www.cars101.com/subaru/legacy/legacy2012.html It is the 4th picture down.
Cheers! |
My 2013 Legacy 2.5i Premium has the same push button setup for its OEM fog light kit.
Recoil, the fog light kit you have may have been a dealer added option because, unless I'm going senile at 43, I looked at a 2013 on the showroom floor and confirmed that the fog light switch was on the turn signal "stalk".
But, then again, I may be going senile at 43. If I get a chance to stop at the dealer, I will take a pic and post it. Cheers! |
If I'm not mistaken, If you look at the link I noted, 3rd pic down on the left, you may be seeing the parking and headlight icon/pic. I thought that at first as well.
The fog light kit was not on the build sheet but its clean install could have fooled me. It is tied in to the fog light indicator lamp on the gauge board. I'm very pleased with the install and performance. I added pics to the gallery.
| All times are GMT -6. The time now is 06:57 PM. |
