Subaru Legacy Forums
-   Second Generation Legacy (1994 - 1998) (http://legacygt.com/forums/forumdisplay.php?f=95)
-   -   H&R springs not right?! (http://legacygt.com/forums/showthread.php?t=196296)
Toallhisdoom 11-13-2012 07:22 AM
So ordered kyb struts and H&R lowering springs for my 98 legacy gt sedan.
The website said 90-98 legacy all models except wagon.
Well fronts went in no problem. Then the rear springs were tapered at the top and would not seat properly on the struts.
So now i am riding around with the front lowered, and the rear on stock springs.
It does not look terrible but i paid 200$ for springs that i can now not put in my car.
Anyone else have this issue?
broknindarkagain 11-13-2012 08:33 AM
Sure. Turn the spring a little bit.
I rode around in my 98 Outback for a day with the rear lowered and the front at stock height....It was awesome
Toallhisdoom 11-13-2012 08:35 AM
Nonono, the tops of the stock springs are the same diameter as the bottom, with the H&R springs the top is smaller diameter then the bottom so it is to small for the strut mount.
broknindarkagain 11-13-2012 09:01 AM
Did you get the front and rear springs mixed up?
Toallhisdoom 11-13-2012 09:28 AM
No the fronts are same top and bottom diameter as well. And the fronts had the letter F on them and rears had the letter R. So no. Lol
Sent from my DROID X2 using Tapatalk 2
Toallhisdoom 11-13-2012 11:47 AM
Dear H&R customer,
Before installing your new H&R springs, be sure to check that the H&R spring shape (size) matches the
factory springs. Some Subarus have different shaped (size) rear springs.
Thank you for choosing H&R!
So wtf are the right springs? GRR
broknindarkagain 11-13-2012 04:47 PM
Call them
Toallhisdoom 11-14-2012 06:43 AM
they said they dont make the right springs for my car so they are issueing a refund. Wow. This is ******* bullshit. I would have just gotten the ******* coilovers if i knew this.
subikid90 11-14-2012 07:46 AM
H&R does offer the right springs for our cars. The ones you have currently sound like they are for the 04-07 wrx's with the tapered springs. The correct part # should be 29868.
Toallhisdoom 11-14-2012 08:02 AM
they have the right numbers and everything and match up with what H&R says they should be. Ugh. This is pissing me off.
subikid90 11-14-2012 08:08 AM
Are you sure you have the right tophats and struts then?
Toallhisdoom 11-14-2012 08:27 AM
stock tophats, and yes right struts. H&R said they do not make the right springs for my car, so...
SCASEYS 11-27-2012 02:55 PM
In for results....
