Should i run a dif oil? Suggestions??
My 97 LGT is just about to turn over 184K miles. I am the second owner and know the complete history of the car. That being said its gotten 5W30 synthetic(Mobil 1 etc) since it was new. I know that oil is kinda thin. I was wondering if there might be a better choice for a higher mileage car? Would it hurt anything switching to a thicker oil since the car has always had synthetic in it? If i should run something dif any suggestions? Keep the same weight oil?
5w 30 is not recommended for hotter climates. i doubt PA qualifies as a hotter climate.
10w30 is recommended for most climates EXCEPT extremely hot or cold. i would run 10w30 since that is the factory spec. but seeing as how the engine has made it this far on the 5w i doubt it makes a difference. but more important than the type of oil is the fact that you change it. i don't think 180k is a significant mileage for selecting a different oil. but oil is one of those things where everyone has an opinion and everyone has a favorite. and we all have a reason it. happy motoring. |
interesting write up. it is so extreme i do not know if i can believe it. but i thought you would enjoy the read.
ROTELLA T6 5w40! GOGOGO
Your dif should always be run with oil.
T6 5w40 FTW. At 190k and switched to that. Engine isn't as ticky and quieted down a lot and just overall feels healthier
Yeaaa budddy! T6 is the best! DDO IT!
Sent from my DROID X2 using Tapatalk 2 |
How expensive is the Rotella T6 oil?
Also what oil filters do you guys run? |
21$ for a gallon at tractor suppply co
Rotella T6 with Wix filters
I run this oil until it starts to get cold. Then I switch to 10W-40. Then when it starts getting really cold I switch to 5W-30. |
Pretty sure that's not the same oil. I've never seen rotella t6 in a 5 qt container.
There are 3 different rotella oils, t3, t5, and t6. The t3 and t5 are in the $14 range and the t6 is around $21. All of them come in 1 gal jugs or you can pick them up in quarts also.
Hmm.. Maybe I'm not remembering right. I do know that it's 15W-40 and $14. I'll go check when I get home.
| All times are GMT -6. The time now is 08:52 AM. |
