heated seats and mileage drop
Does anyone here also experience a mileage drop with using heated seats? I am looking at a 15% drop with just 20 minutes of usage of both seats each day.
heated seats = winter gas?
How much power does one heated seat use on high setting? I wonder if the mileage drop is related to extra load on the alternator.
Not sure about that one. I'm just saying that winter gas blends often return lower MPG's, and since you only use your heated seats when it's cold, it's likely that using the heated seats also correlates with putting winter gas in your car. The drop in MPG has nothing to do with heated seat use, but just the switch in seasons and thus the switch in gas.
Just a guess. |
I get better mileage on the winter blend. I don't see how heated seats could possibly affect gas mileage. Yes, I have heated seats.
Ic, I didn't know about winter blend. thanks!
The heater circuit has a 15A fuse to power both seats, so use of the heater certainly isn't drawing down mileage by any appreciable amount.
winter gas sucks but i love the added power of cold air
is winter blend gas the same quality in all gas stations?
| All times are GMT -6. The time now is 03:01 AM. |
