Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Ordering Valve Cover Gasket - need info (http://legacygt.com/forums/showthread.php?t=196109)
Adoniram 11-09-2012 08:46 AM
So I'm looking at Subaru's site and can't quite understand which parts I really need...
There's the valve cover gasket, the outer valve cover gasket, and the inner valve cover gasket. I figure the inner gasket is for the spark plugs, but I can't make heads or tails of the outer gasket vs just the gasket...
I only need the passenger side, and there isn't a single parts store in town that has the gaskets in stock, so I figured I'd order OEM.
Thanks!
Max Capacity 11-09-2012 10:02 AM
Call the guy's at Fredbeans, a vendor from the vendor link up top of the forum.
mustangendsley 11-09-2012 10:17 AM
your subaru shope will have them. just a gasket and plug gaskets that is it.
Adoniram 11-09-2012 12:05 PM
Sounds good. What are these "half moon" gaskets I keep reading about?
mustangendsley 11-09-2012 12:13 PM
spark plug gasket's
Max Capacity 11-09-2012 12:13 PM
They fit on the back of the cams if I remember right. Into the head not the VC.
I can't post pictures here but in my thread, got some new stuff for engine R&R, I believe there is a picture showing them. They didn't come in the gasket kit, but the guy's at the dealer parts counter took care of me.
ripemeat 11-09-2012 01:11 PM
you can reuse yours if you don't break them. but if you want extras just in case they are not in the gasket kits. also, buy a tube of fujibond at the dealer
Adoniram 11-09-2012 04:06 PM
Oh I'm not taking cams out, so I guess I wont need em
Well, headed to the garage...
Adoniram 11-09-2012 06:01 PM
Ok, so I'm guessing it really is the valve cover gasket... all the oil return lines look good and dry. What do you think?
http://i5.photobucket.com/albums/y17...5265BAF000.jpg
Nrw 11-09-2012 06:24 PM
yup leaky valve cover gasket. Atleast it isn't too horrible to replace. Tight but not a nightmare.
cubedweller 11-09-2012 07:21 PM
subscribed
derffred 11-16-2012 05:57 AM
Mine has been leaking for a while, just started dripping onto the exhaust this morning, as I smelled oil burning a minute after startup. I have the Outer & Inner Gaskets, but need the half-moons pieces as well. I'll be doing this in my driveway on Sunday. Woohoo! (assuming I can get those Half-moon gaskets - anyone have part #'s??)
Adoniram 11-16-2012 08:22 AM
wait, outer AND inner? I thought there was just the valve cover gasket, and the 2 half moons...
ripemeat 11-16-2012 08:48 AM
the spark plug hole has a gasket in the valve cover
Adoniram 11-16-2012 09:05 AM
Yeah, I thought those were the "half moons"
