Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Need help with 05 legacy gt (http://legacygt.com/forums/showthread.php?t=196043)
ric_cfs 11-08-2012 06:01 AM
Hello i current own a 2005 lgt with 99k. i bought the car with a turbo leaking a little oil, so i replace the turbo and someothere parts and have a stage 3 now with a cyro-tuen.
I recently herd a ticking in the motor and had to inspect and when i pulled the oil pan i found a turbo bearing broke in half and alot of metal glitter. i then also noticed that one of the rods had play in it.
So i am in the process of removing the engine to decide if i will rebuild it or do ??
There is a local 03 2.5rs sohc motor with ecu i can purchase for a good price. Will that drop in if i have the ECU with the motor?
If not can i just replace the heads and intake with my stuff and be good to go?
Max Capacity 11-08-2012 06:11 AM
IMO that will not work.
You can buy a new OEM EJ257 for $1900.
Here's my thread.
http://legacygt.com/forums/showthrea...-r-184106.html
ric_cfs 11-08-2012 06:39 AM
IF i am going to rebuild my motor due to metal glitter and a rod nock.
can i use any 2.5 block are all strokes and bores the same?
Danteneon 11-08-2012 09:39 AM
Wait....you found a turbo bearing...broke in half...in the oil pan?
Max Capacity 11-08-2012 10:57 AM
I'm guessing no. Your going to want a EJ255 or EJ257. I gather you have the skills to rebuild one of these.
Yea, I just got past that...IDK.
