Subaru Legacy Forums
-   Suspension/Brakes (http://legacygt.com/forums/forumdisplay.php?f=20)
-   -   Rear sway bar brackets with 20mm bar (http://legacygt.com/forums/showthread.php?t=195989)
m_dogg 11-07-2012 11:02 AM
So i picked up a 20mm rear sway bar (bushings included) for my 2.5i. My question is, do I need bigger brackets or can I get away with stockers? Not sure what's the dia on a stock bar...
Thanks!
sactojesse 11-07-2012 11:21 AM
Get the AVO rear sway bar reinforcement brackets. I'm running the AVO RSB reinforcement brackets with a JDM 20 mm hollow RSB. (USDM RSB is 16 mm solid on Legacies and 15 mm solid on Outbacks.) The stock RSB mounts are really wimpy and you don't want to break one.
m_dogg 11-07-2012 11:38 AM
^Thanks for the tip friend, that was one of the items I picked up with the bar and end links of course :)
Looks like I'll need to pick up a 20mm bushing brackets in this case...
soloz2 06-25-2013 04:32 AM
I've been running the 20mm jdm bar for a couple years without the braces.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
ragman 06-25-2013 06:17 AM
No need to replace the bushing brackets. They give you new bushings that fit the stock brackets just fine.
