Subaru Legacy Forums
-   Legacy Photos (2005-2009) (http://legacygt.com/forums/forumdisplay.php?f=16)
-   -   super tones (http://legacygt.com/forums/showthread.php?t=195964)
Bpalumbo159 11-06-2012 07:24 PM
super tones
i have an 07 legacy and im installing horns and am wondering whhee the signal wire is i conect to for the horns, i bought the harrness . should i just disconnect the horns and attach to one of those wires?
thisisthenewsic 11-06-2012 07:44 PM
Yeah u remove the old horns and the harness should plug right in.
Also Wrong section by the way....
BAC5.2 11-06-2012 07:48 PM
What harness did you buy?
If it was from Subimods, it's probably not built correctly. I'd return it and buy one from AZP Installs.
Bpalumbo159 11-06-2012 08:00 PM
i bought the harness that supertones sell for the horns i just don know which wire to connect to so when you push your steeriing wheel they sound everything else is self explaniory
BAC5.2 11-06-2012 09:07 PM
There is only one wire that will do that, the one connected to the stock horns.
legacy360 11-06-2012 09:25 PM
^^ This. If you have a 4 pin relay, you need to rewire the harness or buy a new 5 pin relay. Otherwise, enjoy a dead battery. :)
Bpalumbo159 11-07-2012 04:49 AM
the harness came with the relay , like i said i just mneeded to know which wire to connect to, thanks bac5.2.
BAspecB 11-07-2012 04:30 PM
Harness should have a one signal wire that you connect to (one) of your factory horn wires in the stock harness. Make sure both of your stock horns are unplugged. Then you should have a power/ground for both of your new hella horns from the relay. Then lastly you should have a power/ground that you hook up to your battery. That is everything the harness should have and pretty easy to hook up. hope that helps a bit.
Bpalumbo159 11-09-2012 07:58 PM
thanks thats what i did , just unlugged them both and auto splicd right to one of them
Drift Motion 11-10-2012 02:48 PM
is the wiring harness REALLY necessary?
I just disconnected the old one, extended the wire to the Hellas
BAC5.2 11-10-2012 09:24 PM
It's necessary if you don't like blown fuses and car fires.
