Subaru Legacy Forums
-   Second Generation Legacy (1994 - 1998) (http://legacygt.com/forums/forumdisplay.php?f=95)
-   -   EJ25 to EJ22 Swap in CA (http://legacygt.com/forums/showthread.php?t=195800)
riz_o 11-03-2012 04:57 PM
I have a '97 2.5L LGT Manual with a seized engine. I plan on swapping it with an EJ22 from a '95 Legacy Auto.
I want to know if anyone has done this CA and had any problems with passing smog?
Thanks..
DOHCEJ22E1 11-03-2012 06:17 PM
You will be swapping in an engine with an EGR system, so if anything, it should pass a smog inspection without a problem.
EJ22Es from 95-98 are plug & play.
riz_o 11-03-2012 06:43 PM
Thanks... Another noob question, how can you tell what kind of engine it is (i.e. EJ22E, EJ22D, etc...)? I found a '95 Legacy engine on Car-Part.com and I want to make sure if it's an EJ22E.
SomethingWittyAsAUsername 11-03-2012 08:11 PM
It's easy to know if you have an EJ22D, seeing as how it was never made :p
That is a motor he made from the heads of an EJ25d on an EJ22E Motor
and the motor should be stamped
Drift Motion 11-03-2012 08:31 PM
Nope, you'll run into problem
motor swap rule: engine must be from the same year or newer than the chassis, regardless of make
of course, you'll have to keep all the smog equipment, and the engine has to be offered in US
this is also the reason why LS1 swap in a FC/FD is completely legal
riz_o 11-03-2012 09:47 PM
Thanks for the heads up. I did more research and looked it up on the CA Air Resource Board and that is indeed the case. Same year or newer engine.
DAMN YOU CALIFORNIA!!!! :mad::mad::mad:
Well there goes that idea.
Anyone know where I can get cheap rebuilt EJ25??? :( :(
Drift Motion 11-03-2012 11:11 PM
but honestly, if it's not too flashy, no one will notice. Keep the smog equipment intact, you might be able to fly under the radar
riz_o 11-03-2012 11:25 PM
That's a big if. I don't really want to invest the time, money and hassle only to find out that it won't pass the referee. Besides I never had good luck with smog checks. Oh well. Guess I'll go find another beater.
r3v_v3ng3 11-04-2012 12:49 AM
Why do you need to go to a referee? If you have to see a referee then don't do it but if you don't and just need to see a regular smog station then if it was me i'd do it. They do fly under the radar, they basically look the same. As long as it has all the sensors on it you should be fine and no check engine light. They just plug in the obd2 and do a idle/2500 test. Quick look and pass! Theres no timing to check and such.
FWIW my friend had a jdm gc8 engine on his gc impreza and he passed smog thru the regular smog station. He had it as stock as possible. This is in the stockton area
johnegg 11-04-2012 06:13 AM
if you swap in the power steering lines out of a ej22 car when you swap the engine no one will be able to tell that a swap has been done. and there is almost no way to tell difference between the a 96 ej22 and a 97 ej22.
and if we can't tell, how the hell will a smog inspector be able to tell?
Drift Motion 11-04-2012 05:31 PM
Another thing is 96 is when they introduced the OBD-II thing, so if you can somehow make that work...go for it
monkeyposeur 11-04-2012 06:58 PM
95 was the transition year for OBDI/OBDII. My 95 is OBDII.
DOHCEJ22E1 11-04-2012 07:35 PM
The 95 EJ22E engine that I picked up for my DOHC conversion was OBDII compliant & california emissions ready. It looks no different than a 96-98 22E. Swap your power steering stuff over & install it. There is virtually no way to tell the difference between 22Es by looking at them when they're out of the car with nothing attached to them. The differences are internal.
twisty 11-05-2012 09:18 AM
my 95 is OBD2 as well, but they refuse to scan it here in AZ. they made it run the full test. also, when i went back after replacing the gas cap and the evap canister, the tech apparently broke a vacuum line to the EGR while "inspecting" it. it passed, 2 miles down the road it popped a CeL. i took a look over the weekend and found the broken vacuum line that i know wasnt there before. jackass. at least he didnt fail me for it, hehe.
oh ya, i hate california. their gun and emissions laws are ridiculous. and their stars carrying pocket dogs.
riz_o 11-19-2012 12:52 PM
Thanks to everyone for their inputs and suggestions. After mulling it over for quite some time, I've decided to go ahead with the swap. I've located a local dismantler that has both a '95 and a '96 2.2L. The '96 is from an Auto but they don't know about the '95. They both have around 100k miles, so it all depends on which engine is in better shape. Also if the '95 does not have an EGR port, then I will have to go with the other. I'm sorta leaning towards the '96, but again it all depends on which engine is in better shape.
Anyways.. What can I take from my engine that I can transfer over to the '96? I have recently replaced the water pump, oil pump, idler pulleys, and the tensioner. I am assuming they will fit? Does the '96 have a different belt tensioner pulley? Maybe I'll just wait until I take the engine home.
Anywho.. Thanks again everyone. I will probably be asking for more help and suggestions later...
