Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Gates Kevlar belt ripped with less than 15k miles :( (http://legacygt.com/forums/showthread.php?t=195783)
ibr_adam09 11-03-2012 11:35 AM
As I was taking a turn the car just turned off. While I was coasting ( under 10 miles ) I tried to start it up again but to no avail. I'm in the middle of tuning so I presumed that the shut off was normal. When I try to start it, it seemed as if the starter wasn't even turning the motor over like something was jammed it. Took a look around, check level. All was good. Had a 10 mm with me ( good to have on hand) and thought to just take a look at the belt and low and behold I found this. It looks as if the belt is still Intacked And no teeth jumped but well see. I just hope this was the reason why it turned off and not another issue I just found.
So I'm sitting here waiting for a flatbed and decided to let you guys know
http://i344.photobucket.com/albums/p...1351963004.jpg
Not my day :(
HAMMER DOWN 11-03-2012 11:59 AM
That sucks, just thinking out loud. Where the belt split. That's is the area where the belt guides ( 5 of them) would rub, if the clearance wasn't set correctly. Or it could be a defected belt.
Mike
Max Capacity 11-03-2012 12:16 PM
Sorry for your problem, at first thought, I'm thinking install error.
Also guessing the reason the starter stopped is because a valve is stuck in a piston.
KuntryQuestTSi 11-03-2012 12:22 PM
Same thing happened to my car. On of the bolts on the center guide fell out and got into a cam gear and jumped time. I was at crusie at 60 and it was like someone pulled all the plugs.
Check your timing first, then do a leak down and prepare to diddly hole for a rebuild.
ibr_adam09 11-03-2012 03:06 PM
Well I found the culprit. A bolt got jammed between the pass. intake cam and timing cover. It looks like a timing belt cover bolt, but not sure where from as I still had all the bolts on the cover. I also need to get a new cover, they all have cracks and openings.
Now I need to align pray that it didn't jump.
http://i344.photobucket.com/albums/p...1351975946.jpg
http://i344.photobucket.com/albums/p...1351975940.jpg
http://i344.photobucket.com/albums/p...1351975937.jpg
http://i344.photobucket.com/albums/p...1351975930.jpg
http://i344.photobucket.com/albums/p...1351975927.jpg
LosAngelesLGT 11-03-2012 03:28 PM
Wow that really knocked around in there. :mad:
LegacyDan 11-03-2012 04:47 PM
i got some metal exhaust cam gears that would look perfect in there!
m sprank 11-03-2012 05:32 PM
Those are ACVS gears Dan.
That does not look good. Pull the belt. Set the crank to TDC. Set the cams to TDC. Install the belt. Perform a compression check. Pray you dont have all zeros. We should all pray he does not have 4 cyl with zero.
BarManBean 11-03-2012 06:18 PM
Subscribed. That's some serious belt carnage there :(
LegacyDan 11-03-2012 08:26 PM
Pa tay toe.... potato!
AkumaMax 11-03-2012 10:15 PM
WOW never seen that before in my life. Now your making me want to double check all my bolts. Good luck man.
ibr_adam09 11-03-2012 10:35 PM
Tried to align it while the belt was still on and marks were off on all four cams. Looked like it Jumped big time, so already expecting the worse. I got the belt off and all the plugs. Tomorrow I'll run a compression test. I also bought new plugs just in case. Also already purchased another Gates belt and starting to look into short blocks (suxs big time if I need one)
Found out the bolt came from the waterpump. Must of loosen itself out after 15,000 miles =/
Oh and, some damage on the pass. cam gears. Might need replacing ?
http://i344.photobucket.com/albums/p...1351989992.jpg
http://i344.photobucket.com/albums/p...1351989996.jpg
05LacyGT 11-04-2012 12:06 AM
See now this scares me as this is the exact belt and water pump kit i have coming for mine next tues. I know you said you had a bolt come loose, but i'm doing the job myself as i can't afford to have someone else do it, aka shop. I have loctite, should i apply that to all my bolts just to be sure? Other than this, how did the gates belt perform?
No DRFT 11-04-2012 05:11 AM
Holy crap
paintpollz 11-04-2012 06:52 AM
plenty of people here have put a 100k on these kits. this was clearly an install error
