Subaru Legacy Forums
-   Suspension/Brakes (http://legacygt.com/forums/forumdisplay.php?f=20)
-   -   Endlinks: Perrin Vs. Kartboy (http://legacygt.com/forums/showthread.php?t=195584)
LegacyKid5 10-30-2012 01:32 PM
So I'm in the process of upgrading my suspension, I'm throwing some swift wagon specific springs on konis, and thinking for sways I'm going to go with perrin, 22mm in front and 25mm in back. Now my question is which endlinks to go with. I'm debating between Kartboys and Perrin and was just curious to get opinions from people who own either, or who have any experience with both. Any advantage of one over the other?
LegacyDan 10-30-2012 03:04 PM
im interested in these too, Perrin are new and not too many long term reviews, Kartboy, are tried and tested and seems to be popular choice
Heedz 10-30-2012 03:20 PM
I have a perrin 22mm with the spherical endlinks... they clunk for some reason.
FPerron 10-30-2012 03:42 PM
They clunk because they are spherical bearing endlinks:lol: My favorites are MSI.
LegacyKid5 10-30-2012 03:49 PM
I was told by a local Subaru mechanic that the old perrin were spherical endlinks and he wouldn't recommend them on any street driven car, as apposed to the new perrin polyurethane endlinks which are comparable to the kartboys.
jhow257415 10-30-2012 10:04 PM
I had the same questions about endlinks? I actually don't have a personal experience with Perrin, but much research info. I would go with Kartboy (I actually went with them) after watching the 5 video manufacturing process on the "tube". They are made of high grade thick metal (aluminum I suppose), 1 piece units, and are extremely heavy duty. Kartboy offers all 4 with washers and hardware for a package deal of $200.00
fahr_side 10-30-2012 11:34 PM
I've been running the Kartboy links for 3 years, no problems with them once properly aligned and installed. Would definitely buy them again.
xero287 10-31-2012 09:28 AM
Get the new perrin ones. The poly bushing type.
PirateDuck 11-09-2012 12:37 PM
I installed the Perrin poly bushing endlinks up front a few weeks ago. They replaced the worn out, clunky stockers and do a great job. They are cheaper than the Kartboy links and are very sturdy.
Max Capacity 11-09-2012 12:44 PM
I have Perrin solid end links on the front of the wagon for a 3/4 years now. Seem to be ok.
Got them from my Tuners web site, www.tuningalliance.com he's a vendor here again.
LegacyKid5 11-09-2012 08:30 PM
Picked up a set of the new polyurethane Perrins front and rear from NWSPECB's sale, getting a Perrin 22mm front sway bar this weekend. Just need to pick up AVO brackets for the rear as well as a Perrin 25mm rear bar.
AZP Installs 11-12-2012 04:49 PM
For the front of the 05-09 LGTs we suggest the KB endlinks. The rears are too short for lowered 05-09 cars so we use the Whiteline rears, they are very well sealed and adjustable, we've installed a ton of KB and WL units over the years.
-Mike Paisan
http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/14...8/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
LegacyDan 11-12-2012 06:05 PM
So lowered about 35mm and the KB rears won't work? Do WL do a solid endlink?
-Mike Paisan
AZP Installs 11-12-2012 07:52 PM
We've found the solid KBs to be too short to accommodate any lowered cars. The WL ones are similar to the stock setup including rubber boots etc. Very resistant to the the weather. They are adjustable (at least when you install them) so you can set them to the proper length not to cause issues of hitting the sway bars like the other solid ones out there.
-Mike Paisan
