Subaru Legacy Forums
Subaru Legacy Forums (
-   Fourth Generation Legacy (2005 - 2009) (
-   -   Engine Light (
AWDylanW 10-30-2012 12:09 PM
Engine Light
Hi guys my engine light is on, and my cruise light is blinking... im confused anyone ever had this?
EJ25subie05 10-30-2012 12:19 PM
the cruise light will always blink if the check engine light comes on. I've had my cruise control light blink without the check engine light but thats a different issue.
you should go to advance and they can pull the code for you for free, then you can work from there. it could be a simple problem such as, gas cap or something more serious like a misfire. so get it scanned and work from there.
AWDylanW 10-30-2012 12:32 PM
awesome thanks, the first day it did it when i got up in the morning the light was gone untill later that night and it hasnt went away since.
EJ25subie05 10-30-2012 12:39 PM
yeah just go get it scanned and if you need help then post back here. GL
AWDylanW 10-30-2012 02:22 PM
Miss in cylinder 4... but the spark pplugs and coil are brand new... so i replaced the wires... still drives the same (drives great) so idk what else could be wrong :(... im going to clear the code then see if it comes back.... by the way cylinder 4 is the back right cylinder when your looking under the hood isnt it?
FJuan 10-30-2012 02:30 PM
Could also be a vacuum leak. Check all the little hoses and make sure they're are connected, along with the "T" fitting underneath the intercooler, behind the intake manifold.
EJ25subie05 10-30-2012 02:37 PM
^2 make sure all of the vacuum hoses are connected. how do you know the plugs and coils are brand new? did you replace them or?
alex843 10-30-2012 02:48 PM
I think his car is N/A.
EJ25subie05 10-30-2012 03:03 PM
haha i totally overlooked that...
AWDylanW: what kind of car is it?
FJuan 10-30-2012 04:04 PM
:redface: Just saw the i, my bad. Still not a bad idea to check the vacuum hoses.
AWDylanW 10-30-2012 09:52 PM
N/A :P it runs with a little more zip it seems like and the light s both are off... think it was just wires :)i thanks all will post again if any different issues :)
AWDylanW 10-31-2012 09:07 AM
The lights just came on again........ it says same thing........ im madddd at this dam car
FJuan 10-31-2012 09:34 AM
Might be possible that the #4 spark plug could be fauling out, even though it might be new. A dirty fuel injector could not be spraying properly, try some fuel injector cleaner.
AWDylanW 10-31-2012 12:16 PM
i still havent reset it or anything either yet its been snowing and raining here and i have no grage :/ ... but ill get some fuel injector cleaner, oh and the two times it has turned on and stayed on, it only turns on when i let it run at idle for over like a minute or two.
FJuan 10-31-2012 02:08 PM
How's your oil consumption?
