Subaru Legacy Forums
-   Interior/Audio (http://legacygt.com/forums/forumdisplay.php?f=22)
-   -   Android Interface (http://legacygt.com/forums/showthread.php?t=195498)
angeltalin 10-28-2012 06:10 PM
Android Interface
Hey going through Ebay i ran accross this...anyone try this out with the dual climate control headunits?
http://www.ebay.com/itm/USB-Android-...6abab9&vxp=mtr
kanazteck261 10-28-2012 06:18 PM
Subscribing...i might give this a try if no one has because it would make life awesome
Sent from my SCH-I535 using Tapatalk 2
angeltalin 10-28-2012 06:22 PM
its 15 more than Leptronix i might give it a shot too
kanazteck261 10-28-2012 06:24 PM
http://stores.ebay.com/Grom-Audio-Di...=p4634.c0.m322
Does look like it requires this for bluetooth. I think you would have to use phone to actually answer the call as well, doubt it reprograms the steering wheel controls.
angeltalin 10-28-2012 06:26 PM
doesn't seem that bad still, especially for those that like our oem headunit look:wub:
racso_dor 10-29-2012 08:09 AM
im not to sure how this works
system60 11-04-2012 10:04 AM
Originally Posted by GROMAUDIO (Post 4143800)
SUBARU compatibility.
The GROM adapter for Subaru can have SAT (satellite) or CDC (CD changer) emulation. SAT emulation is applicable to the satellite compatible vehicles within USA only. For vehicles outside of USA please use CDC emulation.
The following car stereos are tested and supported : GX-806EF2, GX-201JE, GX-201LE, GX-201LH, GX-203JE, GX-204LE, P-206 UNB. If you don't see you stereo listed - please contact us. We also offer 30-days money back quaratee if the adapter is not compatible.
Double-DIN Non-Navigation radios that are equipped with an in dash six-disc CD Changer and Single-DIN radios are not compatible.
lilbrudder 11-04-2012 04:02 PM
I don't think this is going to work with 05,06 as the radio must have a SAT button on the radio. I hope I'm wrong.
SCHM1AN 11-05-2012 10:53 AM
To my knowledge, there's just a tab underneath the button where the "SAT" is supposed to be. If you take the dash off, you should be able to break the tab and then wire something in under that.
Someone correct me if I'm wrong
nipper 11-29-2012 06:21 PM
Been talking to Grom, wont work on anything that doesnt have the proper connector
http://gromaudio.com/docs/compatibility_chart.pdf
The AM CD FM button needs to have another selection like aux or sat for the grom to work. Thats how the tech was explaining it to me.
kanazteck261 02-24-2013 10:06 PM
I ordered it after looking at a video on groms website showing the bluetooth functionality.
I will make a video of its functionality once I receive and install.
As far as using sat function to activate there is a cd option that you can choose that will work if you do not have sat button.
These will be from android prospective mainly, but I will test with my girlfriend's iphone as well.
08Legacy08 02-27-2013 06:13 PM
This looks very promising!
Sent from my iPad using Tapatalk HD
12sechatch 03-15-2013 12:11 PM
any updates on how this works?
I'm picking up a 07+ stereo and was looking at doing this, but have 2 main questions:
1. Does the grom unit plug into the sat/ipod connector in the back of the stereo?
2. Assuming #1 is 'yes', that means I can hit 'sat' when I want bluetooth, and 'aux' when I want the hardwired oem aux-input? Or does one take away the functionality of the other?
kanazteck261 03-16-2013 07:36 AM
Actually just installed yesterday along with reverse camera. Works pretty well via bluetooth. I have a glitch I have to sort out with the track number on the display flickering. Will post up complete review once I figure out issue. Have issue connecting via usb to my phone and playing music via the app, but via bluetooth works flawlessly.
You can change tracks with stereo and steering wheel controls via pandora and any other player you are using on your phone. Also when a call comes in you can answer/hangup via scan up/down on steering wheel controls.
Another cool feature I have noticed. When you turn car off phone will pause music when you get back in and phone autosyncs it plays right where it left off automatically.
12sechatch 03-16-2013 11:56 AM
So the grom unit plugs directly into the sat port? Does it plug in anywhere else?
Also, if you're using a reverse cam, what stereo do you have? Do you you have the stock nav with the stock stereo?
