Subaru Legacy Forums
-   Suspension/Brakes (http://legacygt.com/forums/forumdisplay.php?f=20)
-   -   Anyone seen rotors like this? (http://legacygt.com/forums/showthread.php?t=195011)
ryspec06 10-19-2012 07:36 PM
1 Attachment(s)
Anyone know what can make a rotor look like a record player?
Attachment 131769
I have an hour drive home so you can understand my concern when I started to hear a roar then a vibration in the steering wheel. It got so bad that I could swear that a tire had blown and was coming off the rim. I pulled over to a safe spot but couldn't find anything wrong. Full pressure in the tires and they appeared fine. So I limped it home and immediately put the front end in the air. I checked all the linkage, bushings, and drive shafts and everything is tight. Then I noticed the rotor on the drivers side. It has deep grooves and what looks like hot spots of discoloration. The pads and calipers came off effortlessly so I don't think anything was binding up. These are stock rotors with stoptech pads. I'm not sure where to go from here. Has anyone else had similar issues? :confused:
RedLeg97 10-22-2012 02:24 PM
What do the pads look like?
700watts 10-22-2012 02:50 PM
that be either no pads and or locked piston
Drew888 10-22-2012 06:41 PM
Looks like really bad glazing to me. I'd find a shop to do a very light resurface if the thickness is good (otherwise replace them) and bed your pads in again (if there is still life on them).
rps13de 10-22-2012 08:40 PM
Yeah, I'd also say a sicky caliper piston. Check the pads too.
iNVAR 10-24-2012 10:05 AM
I would not reuse the pads. With grooving like that, the pads are very likely grooved themselves already and will transfer those grooves back onto a new/resurfaced rotor.
I would just get a new set of rotors and pads and check the caliper pistons prior to going out to rebed everything.
GTTuner 10-24-2012 11:03 AM
You need a caliper and/or the slides on the adapter bracket are frozen.
ryspec06 10-26-2012 05:35 AM
I figured I would replace both pads and rotors. I don't want to take a chance that I would ruin the rotors with the old pads and this gives me an excuse to tell my wife I need to upgrade the rotors with slotted. The strange thing is that when I pulled the calipers apart they came off so easily. Could a clog in the brake line or a malfunction in the traction controls do this?
halwith 10-26-2012 05:08 PM
maybe your wheel bearing took a shit.
LegacyDan 10-26-2012 05:31 PM
I had similar lookinv rotor when one of my pistons seized, except when I pulled over to check the rotor as glowing red! Perfect opportunity to upgrade to a "safer bbk" that's how you sell it to widely!
ryspec06 10-26-2012 06:40 PM
I thought of that. I know it's not always easy to tell, but there isn't any play at all. Ill get a chance this weekend to get further into it.
