Subaru Legacy Forums
-   Second Generation Legacy (1994 - 1998) (http://legacygt.com/forums/forumdisplay.php?f=95)
-   -   0T0s Cheap race car build (http://legacygt.com/forums/showthread.php?t=194826)
0Tyrael0 10-16-2012 02:12 PM
Hey everyone, havent been on in a while cause I sold my 99 LGT. I became a total sellout and bought a 2011 wrx instead... My LGT was a great car but I just felt like it was time for me to get into something new for a while.
I know I could bring this to another forum but I know people here are very knowledgeable. Anyway.... my new project is building a cheap race car that I can use for a bit of rally cross. By its very nature a car that will be abused wont be very cheap so I speak relatively haha. The car I have in mind is a 92 Legacy 2.2 that was free and it runs so not a bad start I think.
I plan on pretty much rebuilding it so it can be reliable, but at the same time take the opportunity to give it as much extra power as I can. I would hope to keep it simple cause simple equals less money and time (typically). I know I'm not going to get 300hp out of a 20 year old OB1 2.2, I just want to do what I can with it even if thats not much.
Keep in mind its going to be a true race car. It doesnt have to be street legal, I'm completely open to any ideas. I already have the interior totally stripped, I'm going to have an off road intake made and a strait pipe exhaust. Also shopping around for a place to make me a roll cage.
My current thoughts: well I was thinking keeping the head and intake from the 2.2 and swapping out for a 2.5 block for an increase in compression (251 or 25D?). Unless I could do quite a bit with what I have. My only other thought was a low pressure turbo build but I really like the idea of a responsive NA.
Please share your thoughts and ideas.
EDIT: Oh and some pics of my other cars, Ill post a pic of the 92 later tonight if I can. (I also have a 78 Lincoln Continental)
http://i.imgur.com/yvc0tl.jpg
http://i.imgur.com/4R1iGl.jpg
http://i.imgur.com/0uNGRl.jpg
http://i.imgur.com/Zi81Rl.jpg
michiganSOOB 10-16-2012 02:18 PM
2" lift, lightbar/rally skid plates, huge flaps, BRAID rally Wheels(Cheap, tough as hell), bedliner the bottom 10 inches, thats where i would start at least
0Tyrael0 10-16-2012 02:35 PM
Yeah i have been tossing around suspension ideas. I was probably just going to go with some wrx suspension. I wouldnt want to lift it unless I could keep the rebound pretty stiff. Skid plates are a good idea. For wheels I was thinking some stock forester 5 spoke steel wheels, but I will look into those BRAID wheels. As far as paint I was just going to rustoleum the whole thing.... or bedliner haha, something tough that will never fade.
Kennyfvholla 10-16-2012 04:03 PM
As far as the motor, NA. There's no reason to go turbo with this car. Find a 99 2.5 bottom end. It has Phase 2 internals and Phase 1 pistons. It won't fail you like a 25D bottom end would. If you want, rebuild the lower end with ACL race bearings, crank and rods. That will give you the utmost reliability.
On top of that, some porting of the heads and intake would be a good idea. Look into some cam regrinds as well.
0Tyrael0 10-16-2012 04:10 PM
So the 99 251 is different than, say, the 01?
Regrinds seems to be really popular so I planned on that.
Kennyfvholla 10-16-2012 05:27 PM
The 99 is not a 251, it is still a 25D. The motor as a whole anyway.. It's a 251 bottom end with 25D pistons, 25D heads, intake, etc...
The 2000 and up 2.5 Phase 2 motors have different pistons that are closer in design and volume of the 96 Pistons. You don't want to go that route as the compression will be too high and you will need more upgrades and engine management.
0Tyrael0 10-16-2012 06:28 PM
I see, what kind of compression would the 25d pistons have compared to the phase 2?
Yeah I would really like to keep things simple.
subikid90 10-16-2012 07:26 PM
I disagree...
I just put an 251 with 257 headgaskets and 25d heads. It runs great and has good power. I did not need to do anything special to make it work either. I am around 10.5:1 compression.
Kennyfvholla 10-16-2012 07:30 PM
Originally Posted by subikid90 (Post 4117633)
I disagree...
I agree with what you are saying. My plan is exactly that but with thinner gaskets for around 11.5:1 compression. It's been my plan for a while now as it seems like the perfect motor.
BUT
He has a 2.2 top end. Example: Baddog's motor.
Probably about 10.5:1 or so. That's what everyone estimates using 0.030 gaskets anyways.. Phase 2 would put you closer to the 12:1 range. At least, I am assuming that based off of the math I did to figured out that Baddog's motor is about that and he has a 2.2 top end on a 96 2.5 with the pistons similar to the 251 pistons.
97 to 99 pistons are different. They have a larger -volume
subikid90 10-16-2012 08:03 PM
Ah I should have read...
Good link I have saved from NASIOC with a bunch of info
http://forums.nasioc.com/forums/showthread.php?t=823120
0Tyrael0 10-17-2012 11:13 AM
BUT
Alright so if I got a custom head gasket that was just slightly thicker than "thick" I could use a newer engine and get around an 11:1 compression ratio. 11 is what I was really aiming for. I think I could run premium with an 11:1 with no problems.
That is a good link. Thanks you, and thanks for everyone's information.
So here is where I'm sitting right now.
Reuse 2.2 intake and heads
Try for a 98-99 2.5 from the 2.5rs
Alternative use post 99 with custom head gasket
Grind cams for 2.2 head
Anything else I should be doing to this engine while its out? I'm open to any ideas. Really trying to do as much as I can that is within reasonable money.
Thinking stock 06-08 WRX suspension, perhaps on forester or outback springs? (that will all bolt up the the old legacys im assuming)
Front/Rear endlinks
The biggest rear sway I can find
Also is there a cheap LSD that can be had in the Subaru world?
colby 10-18-2012 01:40 AM
the limiteds have a lsd
Baddog 10-18-2012 10:41 AM
2nd gen limiteds?
0Tyrael0 10-18-2012 11:30 AM
Hmm I had one of those and I dont think it had an LSD.
DOHCEJ22E1 10-18-2012 12:46 PM
I have a 2nd gen Limited & it does not have an LSD.
I don't think the 5spds come with them either.
I know that some of the older Legacy turbos DO come with the LSD though.
