Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   changing my catted up pipe.will a sti stock pipe fit (http://legacygt.com/forums/showthread.php?t=194732)
06legsleeper 10-14-2012 05:22 PM
well im getting my 05 lgt wed... and it has the oem catted up pipe ..
car has 50k miles on it ...
i hear disaster storys of that cat coming apart and messing up the turbo
i was wondering what uppipe will fit .. i was told a sti or wrx pipe will fit 06 and above yrs ,
or should i just get a perrin or cobb uppipe and not worrry about it
i was only thinking of the sti or wrx pipe cause a few of my buddys have there stock catless pipe and i would not have to spend the money on a aftermarket one ... (money could be used toward a catless dp instead)
Nrw 10-14-2012 05:30 PM
yes
joeblow 10-14-2012 06:06 PM
Just for clarification, any year STi, 06+ WRX and 07-09 LGT UPs are catless and will fit.
06legsleeper 10-15-2012 02:32 PM
thank you
stuck686 10-15-2012 02:34 PM
CNT catted is cheaper and a quality fit. Use new oem gaskets
BarManBean 10-15-2012 02:54 PM
You're a fool. Thanks for sharing you newly found downpipe knowledge in an up pipe thread though.
stuck686 10-15-2012 02:58 PM
ah up pipe. noted
lieutenantcolumbo 10-15-2012 04:56 PM
Don't forget to do the resistor mod. It's good practice even if you turn the cel off in the tune.
http://legacygt.com/forums/showthrea...pe-131488.html
06legsleeper 10-15-2012 07:57 PM
yeah i have a coob waiting to get plugged in . should i still do the resistor
06legsleeper 10-15-2012 08:09 PM
as for gaskets im getting the grimspeed 2x thicker one though them ..
as for the down pipe answer im going catless...invidia...
only keeping 1 cat in the middle
RdKetchup 10-16-2012 06:57 AM
Won't going with a catless dp get rid of the last 2 catalysers?
ripemeat 10-16-2012 08:59 AM
the only cats in an 05 gt are 1 in uppipe, 2 in downpipe. the downpipe(oem one) consists of two portions, an upper section and a "mid" section. both sections have their own cat. aftermarket downpipes are commonly 1 piece, catted having 1 cat, catless having none. perrin being the exception with selling a 2 portioned aftermarket downpipe(1 cat however) for no good reason other than being perrin being perrin.
Dujo 10-16-2012 09:22 AM
^ Nice and clean and clear ripemeat. The answer to your question is, yes ... catless sti up. Perfect choice, especially if a buddy has one on the cheap. Get a single free flowing cat in your downpipe (unless you love Perrin for whatever reason). There's no need to be completely catless. Difference of only a couple horsepower.
As BAC says ... "All street cars should be catted."
06legsleeper 10-16-2012 04:21 PM
well i got a uppipe from a friend for 40 bucks off a 08 sti , looks new
as for the dp , i got lucky friend has a catted one im going to pick up fairly cheap he went cattless, so im getting a good deal on the old one prob has maybe 5k miles on it..
think its a invidia.. so that will work
