Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - 2014 ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   anyones cars feels like its gonna stall out (http://legacygt.com/forums/showthread.php?t=194727)
abody 10-14-2012 03:20 PM
Everyone once in a while, my rpm's will drop a little when I stop, at idle, go below idle, then come back up, its not constant so I can't get it checked out yet. Figure it has to more consistant. Anyone else have this or just a subie quirk?
20SWP10 10-14-2012 03:44 PM
Mine and quite number of others have that prob. I couldnt "duplicate" the problem, so they couldnt do anything. Some mechanic over at the dealership said it was something about "programming" issue thats cant be fix yet...there's few threads about this
Regis1756 10-14-2012 04:22 PM
It's a normal thing.
wrxwhit 10-14-2012 04:28 PM
Could be caused by the bypass valve not shutting quick enough under vacuum causing rpms to jump when you change out of gears to neutral when driving.
PoManzAWD 10-14-2012 08:21 PM
There is no idle air control system on electronic throttle controlled engines.
E-throttles move the throttle plate themselves to maintain idle speed.
FWIW, there's about 3 recent threads on this idle stumble deal for 2010+ 2.5i CVTs. It's a programming deficiency that I'm sure SOA will drag their feet on fixing for everyone.
Joel
wrxwhit 10-14-2012 08:25 PM
FWIW, there's about 3 recent threads on this idle stumble deal for 2010+ 2.5i CVTs. Programming deficiency.
Joel
My statement has nothing to do with the iac system, but the bypass valve. Bypass valve rpm bounce. This same thing occurred in my wrx and was able to fix with a blow off valve which closed much quicker than the oem bypass valve.
EMVirostek 10-14-2012 11:00 PM
It's not just the CVTs. My 6MT does the same thing. Been in contact with SOA and they say its normal operating conditions. I got an extended warranty out of them. That's all. I don't see a fix in the near future.
acumenhokie 10-15-2012 07:21 AM
I get a major bounce every now and again with the LWFW. It's normal.
dgoodhue 10-15-2012 07:28 AM
Yeah my 6MT does the same thing. The RPM don't drop much if it all but it sounds like its going to stall.
PoManzAWD 10-15-2012 09:22 AM
This thread is in regards to a 2010-2012 non-turbo EJ 2.5.
mark5032 10-15-2012 09:29 AM
This happens to my car every once in awhile. It has never actually stalled so I don't worry about it.
wrxwhit 10-15-2012 10:09 AM
Ah just noticed no scoop on OP avatar:)
PoManzAWD 10-15-2012 10:26 AM
No sweat.
I always thought it was just the hamster stumbling a bit on the wheel causing the idle blip anyway! :spin:
Joel
abody 10-15-2012 11:02 AM
Thanks for all your responses , I won't worry about it.
BADLEGACY11 10-22-2012 06:01 PM
If yours is a CVT there is a ECM update that I had done on mine recently at the dealer and it made a world of difference in the operation of the CVT. Similar issues as yours. I think there is a TSB for it.
