Subaru Legacy Forums
-   Member Classifieds - ARCHIVE (http://legacygt.com/forums/forumdisplay.php?f=86)
-   -   FS (IN): 1997 LGT Sedan - MISSING INFO and PHOTOS (http://legacygt.com/forums/showthread.php?t=194648)
TheRude1 10-12-2012 07:45 PM
Year, Make and Model: 1997 Subaru Legacy GT Sedan
Color: White
Miles: 176,000
Transmission: 4spd auto
Title: clean
Lien: none
VIN: 4S3BD6753V7202606,,, Made in Lafayette IN
Seller's email address: therude1@comcast.net
Asking Price: $1,800 FIRM
Background Information
97 Leg GT, 176K miles,
Last 5K miles vehicle has had. Timming belt/pulleys/water pump/oil pump/tennsioner, heads decked,valve job(3 exh valves replaced) seals,head gaskets, rac and pinion unit inner/outer tie rods,rt front wheel bearing,rt ball joint, frt pads and rotors,rt frt caliper
The down side, front main tranny seal leaks. I park it on a couple of 2x4's and nose it up and it will need a half qaurt every 4 or 5 days. If you park it flat you will need to add a half qaurt every other day. A subaru tech drove it and told me the center diff pump is bad so I bought the $200.00 of parts to fix it but never had it done( the parts included)
Current set of Goodyear RS-A at about 20%. will throw in a set of Falkin Azinus at about 60%
Rt frt healamp mounts goofed up but stays in and works
This was a rain and snow car for me but it always starts and runs good
Otherwise the regular rust on the rear body sides and a couple of dings but no major damage and the interionr is clean. Under body and frame are in great shape
PW,PL,PM,cd and cast have never been used cause I dont know if they work and did not want to loose a cd to find out,sun roof opens but will not go back and AC does not work
$1800.00 firm
John 317-694-7519, Daily 9am to 9pm
SBT 10-12-2012 09:29 PM
OP, inserted our required Cars For Sale template into your thread. Please complete the information. Load all photos to the site using the Manage Attachments Process. Linked photos are not permitted in the Marketplace and have been removed.
Questions, PM any of the staff.
