Subaru Legacy Forums
-   Wheels/Tires (http://legacygt.com/forums/forumdisplay.php?f=43)
-   -   Repair Curb Rash (http://legacygt.com/forums/showthread.php?t=194618)
mass-hole 10-12-2012 08:33 AM
Repair Curb Rash
Has anyone ever tried to repair curb rash? I have 06-07 spec.b wheels and they would be beautiful but the PO curb rashed the **** out of them. Is there a way to restore them and make it so they can be powdercoated later. Some kind of metallic laced filler or something?
Thanks!
bluesuby 10-12-2012 01:34 PM
If they are that bad, maybe you want a professional. If they're not too bad a little paint might do. Or use them for mounting snows and buy another set (a number are for sale on this forum).
mdzowner 10-12-2012 01:37 PM
there is a sweet you tube video using a two part epoxy resin.
TheDon427 10-16-2012 07:27 PM
It's very easy to do. I've done write ups on it (nasioc) and can be done in an hour. Don't use bondo. Use a metal filler. I prefer a product called Aluminox which is used to repair boats. It can be sanded, drilled and painted. It's a putty that you easily spread over the rash, let drive for 5-10 min then sand smooth. Prime, paint then clear.
SpecBlitzed 11-13-2012 08:04 AM
Is the rash isn't bad you can sand it out. Or find a welding shop to fill in the rashes.
GTTuner 11-13-2012 09:40 AM
I used JB weld on my 17's, it's holding up great. Good luck trying to find the paint code for the wheels. It seems to be a trade secret.
paintpollz 11-13-2012 10:04 AM
I should post a pic of my stock winter wheels. I'll show you rash. NH winters, power sliding fun, and granite curbs. You get the picture......
outahere 11-13-2012 03:00 PM
Fill in the low spots with metal filler, as others have already advised. Or take off the high spots on a lathe, but be careful not to take off too much metal from the lip.
Firepuma 11-16-2012 01:31 PM
Just bring them to rimpro in Tewksbury
