Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   Quick Question for Wheel/rim size 2010 LGT (http://legacygt.com/forums/showthread.php?t=194576)
hopeforcash 10-11-2012 09:15 AM
As with a lot of people, I am preparing for winter for my newly acquired 2010 LGT. I am wondering if a 2007 OEM 17" 5 spoke rim from a 2007 LGT fit well on the 2010 LGT. I am guessing from reading other threads that the 17" will be paired with 225/50/17 tires?
Thanks in advance
TheOneDoubleN 10-11-2012 09:39 AM
Yes, the wheel will fit, and yes, the comparable tire size would be a 225-50/17
hopeforcash 10-11-2012 10:10 AM
Thanks!!
wrxwhit 10-12-2012 08:51 PM
Or use the oem's for winter with some sweet Blizzaks and get some summer wheels for next year.
hopeforcash 10-12-2012 10:10 PM
2 Attachment(s)
My OEMs are 18s and I would prefer to go 17s for winter.
Also, I tend to like OEM/stock rims for now.
This leads to another question as to a 2006 LGT 17 5 spoke. Are these the same as the 2007s? Will they fit nice?
canadianelbow 10-12-2012 11:07 PM
For winter rubber, why not step down to the base 2.5i 16's? More sidewall could be a good thing in the winter for ya... And tires are cheaper to boot.
hopeforcash 10-12-2012 11:12 PM
I have read and correct me if I'm wrong that the 2010+ Legacy GT requires the 17" to clear the brakes and 16" won't fit.
TheOneDoubleN 10-13-2012 01:00 AM
I believe I read that too (though I'm also not sure myself).
I know, helpful post, right?
Scooby-GT 10-13-2012 01:15 AM
The 4th gen LGT 17" wheels do fit the 5th gen no problem, but the offset is totally wrong. It will look extremely sank in. I know because I tested them on my 2013. You will need about a 25mm spacer to make it look proper.
minuccims 10-13-2012 09:14 AM
16s will not fit because of front calipers.
5th gen are 18x7.5 +55mm offset and way sunk in. 4th gen LGT rims are 17x7 +55mm offset and way sunk in.
Now, listen up. 3.6R rims are 17x7.5 and are +48 offset; not as sunk in...
Tire rack now has 17" steelies.
Subie_Mick 10-13-2012 09:16 AM
1 Attachment(s)
Is this what you want to do?
Yes it works, no issues.
hopeforcash 10-13-2012 02:09 PM
How sunk in is it? What is the offset? Is it from a 2007? Is there a difference in OEM between a 2007 and 2006?
I ask as I am looking at rims that are currently on sale locally.
Questions, questions :eek:
Subie_Mick 10-13-2012 08:30 PM
I dont know what the offset is. I do not think they are bad, IMO it does not look sunk it. If it is I dont think by much maybe even a good thing to keep the grime off the car.
The pic is from last year and I dont have them on this year yet.
