Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   05' Legacy GTL CEL question (http://legacygt.com/forums/showthread.php?t=194556)
Euphya 10-10-2012 10:21 PM
So I just picked up a 2005 Legacy GTL at a used dealership and everything seemed perfect. As life goes, 30 miles after driving it off the lot the check engine light came on steady and cruisse control started blinking. I wasn't driving too crazy or anything so I doubt I caused the problem and suspect the dealership had disconnected the battery.
I took it into autozone and run the codes and it popped up with four possibilities.
1. Low or dirty motor oil
2. Blocked oil passage
3. Timing belt misalignment
4. Failed AVCS solenoid
I just put 6,500$ cash down on the car and almost broke the bank doing so. I am going to get a oil change tomorrow but in the meantime I am very nervous that one of the other two problems could be the issue and they don't sound cheap.
I have no idea what 3 and 4 mean and what the likelihood of those being the issues are. Can't someone please explain them, potential cost, seriousness of problem and what the likelihood of it being that issue.
I am trying to mentally prepare for the worst but its hard when I'm not sure what the worst holds for me.
Thank you all in advance.
Jonathan
Gex 10-10-2012 10:26 PM
What code... Use the search function... Take car back to dealer...
Max Capacity 10-11-2012 08:39 AM
Don't you have a 30 day warranty ?
Make them fix it.
What was the code ?
dingbang 10-11-2012 08:54 AM
Sounds like they made sure to clear the codes before you drove it and before you took it off the lot...dirty.
AZP Installs 10-11-2012 11:52 AM
That's awful. What code number? Also I would return it and make them fix it.
-Mike Paisan
http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/14...8/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
BarManBean 10-11-2012 12:52 PM
As others have said, take it back. Many codes don't pop up right away, some can take a couple hundred miles before that pop back up after being cleared.
The dealer likely cleared them and the car was (lucky for them) not driven enough before you purchased the car to have the codes pop back up.
iNVAR 10-11-2012 12:55 PM
bring it back, period.
