Subaru Legacy Forums
-   Member Classifieds - ARCHIVE (http://legacygt.com/forums/forumdisplay.php?f=86)
-   -   WTB: 05-07 fog lights and surrounds (MA) - LOCATED (http://legacygt.com/forums/showthread.php?t=194339)
aac0036 10-07-2012 08:32 PM
Hey everyone, trying to get my hands on fog light lenses and surrounds with necessary mounting hardware. Basically all I need is what's seen from outside the bumper. 2005-2007 fitment only, color does not matter as I plan to paint them black. Located in Massachusetts.
Thank you :)
BAspecB 10-08-2012 12:54 PM
Just a heads up. Fogs from a 04-05 wrx will work and mount in just fine. The legacy covers fit over them as well. You will beable to find them much cheaper too. I actually found them to be more convient. The adjusters for the beam are on the front vs. legacy on the rear. You can adjust the wrx ones in minutes and the legacy ones the splash shield needs to be dropped.
aac0036 10-08-2012 01:39 PM
Really? That's interesting, thanks for the let-know. Same mounting and everything?
BAspecB 10-08-2012 09:48 PM
Yes sir. Two studs on the bottom, no modding needed. Sets can be found for under $100 on ebay. They also use the same bulbs/harness obviously.
I think I might have been one of the first ones to figure it out. I got a line on a set locally and scooped them up and sure enough they worked great.
Drift Motion 10-09-2012 12:11 AM
that's some great info!
I was thinking about the same as I was searching for the clip that holds the bulbs in...
aac0036 10-11-2012 04:18 PM
No longer looking, thanks for those who helped!
