Subaru Legacy Forums
-   Third Generation Legacy (1999 - 2004) (http://legacygt.com/forums/forumdisplay.php?f=96)
-   -   windows or sunroof dont work, 2 clicks every 10 sec? (http://legacygt.com/forums/showthread.php?t=194299)
cpundyk 10-06-2012 10:12 PM
My windows or sunroof dont work and i here 2 clicks every 10sec from under the dash.. this will go on tell my battery dies (even with keys out) I checked all the fuses. all were good. It quit doing it once i layed down to listen for it.. Has anyone else had this problem, what did you do to fix it?
octain11 10-07-2012 07:04 AM
check the relays and the voltage on the battery, should be getting atleast 14 on the battery
cpundyk 10-07-2012 09:17 AM
Alright. I checked them everything was getting 14 but everything is working correctly and will quit for a minute then start working again. Does it when I'm in the house. ( I leave a baby monitor in the car to listen) so it kills my battery after time. Do relays act like this before they go out? If I pin point the clicking noise is that where my problem is or to do with that system. No CEL
octain11 10-07-2012 09:25 AM
play around with the relays, switch them around to see which ones are working and not
