Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Heater not getting hot??? (http://legacygt.com/forums/showthread.php?t=194273)
Lanaue 10-06-2012 01:41 PM
Hello and thanks for reading this.
I have an 07 LGT and my heat only blows warm on the drivers side and cold on the pass, the car is at op temp. It's getting cold and I don't want to hear my wife's mouth about it. Has anyone else had this problem? If so is it an easy fix? Thanks again.:spin:
ericem 10-06-2012 03:45 PM
search try flushing the heatercore otherwise you need a new core.
TenzoGT 10-06-2012 04:34 PM
It sounds like the control head, "the thing you change temp and blower settings on"in the past I have seen that being the problem more than anything. Especially when it gets hot on one side and cold on the other. That to me points at the control head which is what sets the temp on each side.
fly_navy 10-08-2012 11:18 PM
Had something similar happen to our old 4runner. Ended up having to replace the heater core :(. Best of luck
Lanaue 10-16-2012 06:04 PM
gonna drop it off monday and let the dealers deal with it. I'll update you guys when I get it back.
racso_dor 10-20-2012 12:13 PM
My buddy had the same problem. He had the heater core replaced the wala the problem went away. Deff try your local mechanic becuase it is a pricey job
stuck686 10-20-2012 12:30 PM
thermostat?
iNVAR 10-20-2012 02:50 PM
I'm inclined to agree with this.
iNVAR 10-20-2012 02:51 PM
it's voila, not wala... it's French. arggghhh
TenzoGT 10-20-2012 05:53 PM
Any updates yet?
Lanaue 10-20-2012 06:39 PM
Not yet dropping it off monday, i'll update ya'll when I get it back.
racso_dor 10-21-2012 05:04 PM
check this out bro
http://legacygt.com/forums/showthrea...ei-129814.html
ssbtech 10-22-2012 08:31 PM
My dealer first did a "cooling system flush" which didn't take care of the problem.
I took it back and had them flush and back fluch the heater core and it restored heat on the passenger side.
YMMV
Hson 10-22-2012 09:34 PM
I had a similar with an A4 I owned and it had to do with the thermastat for the climate control being stuck. You could change the temp all you wanted, and it would show on the display but the computer wasn't registering it.
racso_dor 10-23-2012 09:39 AM
i'm curious to find out what the problem is
