Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - 2014 ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   help find thread please, on hid squirl finders. (http://legacygt.com/forums/showthread.php?t=194101)
mosthated 10-03-2012 01:20 PM
im needing help to find where the thread for the diy to have a clean cut off on my factory projector lens. i found a company here in houston tx who will paint my headlights for 100 dollars with warrenty. so while they have the lens off i can go in and fix the cut off on the lights. so if anyone can point me the right direction would be most greatful.
JLGT 10-03-2012 02:51 PM
This should help
https://www.google.com/search?hl=en&...MIK_igKLqIDwCQ
blklgt05 10-03-2012 06:31 PM
Buy the strongest aluminium back high temp tape at home depot (its the big roll, around $20). Bend the metal flap up, use the tape and cover the opening, then bend that metal flap back to where it was. I used a flashlight thru the projector to test the cut-off and make sure no lights were leaking before re-installing the headlight.
mosthated 10-04-2012 09:01 AM
hey thanks guy lots of info for sure.
Aaron48 10-06-2012 09:54 AM
So the objective is to just cover that little hole completely right??
Does the little flap need to be there or can it be removed completely?
I suppose it could just stay and cover the hole right..?
http://legacygt.com/forums/picture.p...pictureid=7437
JLGT 10-06-2012 03:12 PM
I just folded the flap down to cover the hole, way easy when the headlights are taken apart.
mosthated 10-07-2012 10:29 PM
so just fold it????? it won't mess nothin up?
MasterPeon 10-08-2012 09:16 PM
mosthated, you can't bend the flap down or up with the 2012 model like the previous years could. I remember reading posts where other users confirmed this for their 2012 and 2013 Legacys. You're going to have to plug it.
