Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   This the correct rotor for the 05 lgt sedan? (http://legacygt.com/forums/showthread.php?t=194003)
lee07 10-01-2012 06:08 PM
For the front
http://www.partsgeek.com/ptx582g-sub...ake-rotor.html
spritefiend 10-01-2012 07:16 PM
yep that's the correct front. I think amazon might be a little cheaper though.
they're sold individually, so you need to order 2 of each.
lee07 10-01-2012 07:53 PM
Thanks, looks like partsgeek is cheaper by $2.
Brake pads, Should I get new ones as well? I just put in new ones in like May or June
Should be fine I think
spritefiend 10-01-2012 08:50 PM
it may not be cheaper after shipping, if it still is then cool :)
you could use the old brake pads if you want if they still have good thickness and have life left then go for it..
HAMMER DOWN 10-01-2012 09:13 PM
Yes for new pads. Good rule of thumb, New rotor = New pads. Whatever imperfection (groves) that are in your old rotors are now is in your old pads. Which you will transfer to your New rotors.
Now I have used old pad in the past (more then 40% left). But I "recondition" them. I sanded them flat & smooth again. Getting rid of the imperfection. If money isn't an issue, I would just buy new pads.
Mike
spritefiend 10-01-2012 09:22 PM
he's right, you really should do new pads.. but you can get away without it. if it were anything but a daily driver it'd be more important, but it won't kill ya*.
*it might, and i'm not responsible.
patom 10-02-2012 07:23 PM
I have a 2009 legacy 3.0R. I had a r/r caliper pad delaminate and ruing the rotor. I ordered a set of brake pads and 2 rear rotors from NAPA. When my mechanic took the wheel off we matched what NAPA sold me and it didn't look the same. I went to VIP and there brake pads and disc showed the same as NAPA parts did.
VIP did a reference check on the 2009 legacy and apparently what I have is a 3.0R with 2.5 brakes. Is this possible? Or is this supposed to be what I bought?
compsurge 10-02-2012 07:44 PM
Why are you getting new fronts?
If it's because they are "warped", save your money and try the methods posted all over the internet.
compsurge 10-02-2012 07:48 PM
2.5GT or 2.5i?
This site might be useful to you: http://opposedforces.com/parts/legac...em/rear_brake/
That being said, I'm not sure which is actually stock. I did a cross-reference on rockauto.com; both the rear rotor and brake pad of the 3.0R share the same PN with the 2.5i. Hope that helps!
Danteneon 10-06-2012 07:24 AM
Originally Posted by compsurge (Post 4097469)
2.5GT or 2.5i?
Correct. The 3.0R has the same set-up as the 2.5i (and the OBK XT). The 2.5GT has a different set-up.
patom 10-07-2012 06:05 AM
Thanks for your replies. I called Subaru in Bangor and they said that they use the vin number of the vehicle to determine which brakes are applicable.
What was funny was that NAPA still didn't show any difference in the pads, even though I brought in my original equipment pads in to show them the difference. They were able to find the correct rottors. I had to go to VIP for the pads.
While I had it in the garage we checked the front brakes and I'll need to replace them in a month or so. I hope I don't go through the same song and dance to get the correct parts with that project.
Thanks for your responses.
Max Capacity 10-08-2012 09:24 AM
Have you tryed one of the vendors on this forum for your brake parts ?
AZPinstalls.com might be a good place to start, they out NJ. Hit Mike up on his contact page off his site.
