Subaru Legacy Forums
-   Tuning (http://legacygt.com/forums/forumdisplay.php?f=84)
-   -   Cel with no codes ? (http://legacygt.com/forums/showthread.php?t=193897)
Rester5350 09-29-2012 08:26 PM
Cel with no codes ?
My CEL came on tonight after ten minutes of easy driving. I went home plugged in the AP and there are no code but the light is still on.:confused:
So I pulled a memory snapshot and it wont open on my computer .For some reason it wants to play as a media file and comes up unreadable. WTF I just ordered an etune yesterday!!!:spin: Any one have any experience with this?
Rester5350 09-29-2012 09:05 PM
A little more info, its an 06 Obxt 5eat with cobb stage 2 tune.
COBB Tuning 10-02-2012 08:05 AM
Hi. Sorry for your troubles. You won't be able to make any sense out of the memory snapshot - it is a raw dump of RAM and only for use by our engineers. However, you can post it here and I can see what the issue is with the code. Feel free to rename the file extension if needed in order to post it.
Bill
Rester5350 10-02-2012 08:37 AM
Bill
Thanks Bill, I will post it after work tonight.
Rester5350 10-02-2012 09:16 PM
Not having much luck Bill. I will try again tomorrow.:spin:
Rester5350 10-02-2012 09:38 PM
1 Attachment(s)
I think I might have got it, hopefully this works.
COBB Tuning 10-03-2012 07:53 AM
That worked. The bad news is that the ram dump is not complete - something on our end with this particular function. So I am not able to determine what code is being set. Can you take the car to a local auto parts store like Autozone and get the code read? They will often read the code for free. Then I can determine why the AccessPORT is not reading your code and get that fixed. Sorry for the inconvenience.
Bill
Rester5350 10-03-2012 10:23 AM
I am out of town until Friday or Saturday, so I can have it looked at when I return. Thanks again Bill!
Josh
Rester5350 10-06-2012 07:56 PM
I started my car on friday night and no cel :). This morning when it started the cel was flashing. I took it to a local auto parts place and they couldnt find any codes either, pending or active. After shutting the car off and restarting the cel was gone. The car ran fine with the light on, no noticeable difference. I did remove my heat shield that was rattling so maybe that will help. Has anyone seen a flashing cel, any experts out there want to chime in?:spin:
COBB Tuning 10-08-2012 10:23 AM
Flashing CEL means a misfire. Doesn't always result in a permanent diagnostic trouble code.
Bill
Rester5350 10-22-2012 10:29 AM
Just to update everyone, after a while with no heatshield the cel has not returned. This leads me to believe the shield was the cause. Thanks for the input everyone! :)
ripemeat 10-23-2012 01:49 PM
Unlikely.
Rester5350 10-23-2012 01:51 PM
:orly: and why is that?
ripemeat 10-23-2012 01:55 PM
Heatshields with or without them do not cause codes. Unless you've damaged something removing the heatshield. I haven't had a turbo heatshield on for well over a year. How old is your car battery?
Rester5350 10-23-2012 02:04 PM
The heat shield had been altered and the passenger side could not be bolted down. The two bolts on the motor side were in, so on startup the movement from the engine caused the heat shield to rattle. It started shortly after the hs was installed and stopped emediatly after removal. Sounded horrible at a stop. The battery is a relatively new optima red top.
