Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - 2014 ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   Anyone put the 2013 front sway in an LGT yet? (http://legacygt.com/forums/showthread.php?t=193858)
DrD123 09-29-2012 07:06 AM
I have the part numbers, and want to order it, but I am worried the shape might be different since it's no longer going around an EJ engine - has anyone tried yet, or does anyone know if the shape is the same?
Parts numbers (from Subaruonlineparts) for the bar and bushings are:
STABILIZER F D26
Make: Subaru | Part#: 20401AJ00A
RUB BUSH STABI D25
Make: Subaru | Part#: 20414AJ10A x2
Rutchard 09-29-2012 08:20 AM
The GT has a different front bar than the 2.5i, I doubt they can be swapped.
DrD123 09-29-2012 08:59 AM
Based upon several online parts sites, I am pretty sure they are the same - the 3.6 uses a different bar, but the ones for cars with the 2.5 engines are all the same. (the springs and struts come up different, though)
Rutchard 09-29-2012 03:05 PM
you're right, the 3.6R is the unique front bar out of the 3 models.
sschmelcke 10-01-2012 09:14 AM
Ive done the 3.6r one.
nadracer 10-01-2012 11:18 AM
We finally have a mod you gt's can't get so easily done:lol:
fahr_side 10-01-2012 11:34 AM
Whiteline have a 26mm bar for the GT...
acumenhokie 10-01-2012 11:42 AM
still gotta lift the engine/drop the subframe. :(
sschmelcke 10-01-2012 12:06 PM
[QUOTE=nadracer;4094848]We finally have a mod you gt's can't get so easily done:lol:[/QUOTE
plus no lifting the engine for us :spin:
GTEASER 10-01-2012 12:16 PM
OEM on a 2010+ GT is 23mm right?
sschmelcke 10-01-2012 12:16 PM
yes
nadracer 10-01-2012 12:33 PM
Yeah I did say "not so easily done" not that it couldn't be done and not that there isn't one available. I did mine with simple hand tools and no unbolting the engine; just some twisting to thread it through.
DrD123 10-01-2012 07:42 PM
So installation difficulty aside, does anyone know if the 2013 26mm bar will fit? (the Whiteline one is an option, but the Subaru one is $70+shipping online... vs. >$200)
nadracer 10-01-2012 10:43 PM
The 26mm is very straight for the 3.6R. With only two small humps equally spaced for the exhaust. Take a look under your car and see how straight your bar is. If its got a lot of bends in it then your out of luck.
DrD123 10-02-2012 06:30 PM
I am not looking to install the 3.6R 26mm bar in my LGT - that clearly wouldn't work - I am looking to install the 26mm bar from the 2013 2.5i. (the fitment concern is based on the departure from the EJ engine - I didn't know if there were any extra bends, etc. to clear the new engine design) - the part numbers in my original post are for the 2.5i bar.
