Subaru Legacy Forums
-   Tuning Alliance (http://legacygt.com/forums/forumdisplay.php?f=121)
-   -   Accessport & Open source Remote Tuning Available (http://legacygt.com/forums/showthread.php?t=193791)
Tuning Alliance 09-27-2012 08:30 PM
1 Attachment(s)
Tuning Alliance has long provided several forms of remote tuning. Available for a variety of fuels like 91acn, 91, 93, and even race gas. Our ignition and fuel maps have been developed row by row, testing the entire rpm and load range on a chassis dyno. This has yielded the basis for completely custom maps, that have a uniquely smooth feel along with increased power throughout the rpm range.
Most tuners simply take the factory map and edit the high load tables. They have not had vast amounts of time to tweak and test every cell in the map. Thus only the increasing power in full boost situations(high load). The low and medium load parameters are not fully optimized. Considering your primarily driving in low to medium load all the time (unless your a racecar driver) you may wants these areas optimized.
This is why customers report increased smoothness, power, and even MPG.
"I flashed your map this morning and WoW. I could feel the slight differences, it's hard to pinpoint exactly what but the car ran A LOT smoother."
"Have been driving the car for a few days with the new tune. First thing I notice was the engine runs much smoother than the cobb tune. Throttle reponse is more natural than the cobb. I've been getting better gas milage so far as well. "
The two basic types of remote tuning are custom mapping and e-tuning.
Custom maps are for stock to moderately modified cars. Including changes to the intake, exhaust, and intercooler.
E-tunes are for moderate to heavily modified cars. Including larger turbochargers, altered fuel systems, and aftermarket boost control systems.
Not only do we provide quality maps and tunes, but there are other benefits of running a TA map. Continual support, trouble shooting, and discounted map updates to name a few. After a map is installed logging is encouraged to insure everything is responding as expected. TA will edit the map or advise of potential mechanical issues, until the car is running 100%. The same goes for E-tunes, there is no limit on the amount of revisions. If you buy the map in the summer time and want to have your logs checked in the coldest months of winter. Your logs will be reviewed and revised if needed with no additional charge. If new tables are defined that provide a safer, more reliable tune, your map will be updated at no charge.
Our map update program is intended for existing customers who have made minor changes to there car or have moved to new locations with different fuels or altitudes. These maps will be revised for a small fee of $30.
Current pricing for Cobb Accesport tuning (Subaru's Only):
Custom Maps $75
E-tunes $150
Map Updates $30
Open source Tuning (Subaru's only):
Custom Maps $150
E-tunes $200
TA vs Cobb Graph
BMA44 10-02-2012 02:48 PM
pm sent!
Tuning Alliance 10-02-2012 04:21 PM
Responded Thanks!
BMA44 10-04-2012 06:48 AM
mike, thank you for getting me the base map and revision so quickly. this is a really smooth map compared to the OTS stage 1 93 octane. on the way to work this morning, the car was consistently boosting in the high 16's low 17's!! very happy with this tune.
i highly recommend mike and TA for an affordable custom map with excellent customer service!
*****update***** the engine has had some time to dial in the map. all I can say is WOW. throttle response is MUCH better and i'm consistantly boosting in the mid 17's with a high of 17.8. really happy with this stage 1 tune.
Tuning Alliance 10-10-2012 05:19 PM
Tuning Alliance 10-10-2012 05:21 PM
1 Attachment(s)
Rester5350 10-10-2012 07:26 PM
Hey Mike, thanks for taking care of my question tonight. I could not be happier with my tune, boost comes on smooth and strong! I will fix my little leak tomorrow and get some more logs to you.
Josh
hadvw 11-14-2012 04:29 PM
Just curious - for an e-tune with bnr16g, dw650s, walbro, partially gutted stock pipes, do you need a wb02 for tuning?
Tuning Alliance 11-14-2012 06:45 PM
It is not required, but it will certainly help and yield a higher quality tune.
BigInALegacy 12-16-2012 08:25 AM
Long time member who's since moved on to the STi crowd. Just wanted to talk about my experience and sing my praises for Mike/Tuning Alliance's maps.
Mike's been tuning my 2 cars for over 5 years now. I bought a 2008 LGT (auttomagic) fresh off the trucks, which after a brief break-in period I obviously felt the need to mod out. Having heard great things about TA and also with his location being close to me in MA, it was an easy choice.
Got the Cobb AP and got a Stage 1 E-tune from Mike. That ran great for a while, car was much smoother than stock. Power delivery was right, no "dip", car was overall more fun to drive. Stayed there for about 12-18 months, then jumped to stage 2 with a gutted DP and perrin CBE. Appx 25-30k miles going to Stage 2.
Clearly Stage 2 was night and day. Car ran awesome and was a hell of a lot more fun to drive. I was able to go see Mike at his shop, and we did some road tuning sessions to get my stage 2 tune right rather than sending back and forth logs. He took the time to jump in my car and take care of it, something I hadn't expected so that was awesome. Going through each stage also gave me an appreciation for the gains given by each. I drove that at stage 2 until about 60k miles, and then got the urge to go car shopping.
Ran into a 2010 STi Special edition that someone had cancelled their order on. Got a good trade in on the LGT, and stripped it down before sending it for trade for my new STi. Upon purchase, the butt-dyno would say that the LGT with Stage 2 was faster than the STi stock, despite the LGT being an auto. I knew the Cobb AP would transfer right over, so I was pumped to see the gains I could get from the STi.
Emailed Mike up quickly, he remembered me and told me he'd hook me up on a Stage 1 E-map for the new car. Instantly my new baby was faster than out of the gate: quicker, more responsive, better power delivery than stock. It's amazing how much Subaru leaves on the table/Mike can squeeze out.
Much like the LGT, Stage 1 served its purpose for a while and it was time for the next thing. Threw a new HF catted DP on the STi and got Mike to send me a new map for Stage 2. STi with Stage 2 is like a bat out of hell. Easily one of the fastest cars I have personally ever driven. Even had some trouble with the AP loading the new map, and Mike was able to kindly point me through my PEBKAC problem over IM (thx Mike!). There was a day or so I couldn't load the TA map, that I ran the Cobb OTS Stage 2. Putting Mike's map on was night and day to the Cobb, whereas the Cobb felt very noticeable but conservative, Mike's felt engaging and powerful.
Mike has been very responsive to emails, IM's and otherwise helpful during the 5+ years tuning my 2 Subaru's. I've had several map revisions, multiple cars, and multiple other run-ins with Mike and they have all been great. Never had any issues with the LGT with about 60k worth of his tunes on it, and the STi is running strong at 30k+ at Stage 2 now (~20k at Stage 1).
Living in fairly close proximity and knowing his familiarity with Subaru vehicles, I even called upon Mike to do my 30k service and some other work on the LGT when I had it! He changed all the fluids (tranny, gear, coolant, brake fluid) swapped in good synthetics which he had procured for me at a very reasonable price, and lastly through on some Hawk pads all around. Having Mike do the work with all sythetic fluids, plus a brake pad install, was still cheaper than my dealer wanted. As I mentioned the car ran for another 30k before I traded it, and I actually know the guy who bought it from that dealer who is still driving it without issues.
I would HIGHLY recommend Tuning Alliance maps for anyone looking for an economical, safe, and powerful tune from a trusted Subaru guy. Product is stellar, and is only outmatched by the customer service Mike provides. I've sent a couple people to TA since who have been happy as well.
Once I payoff the STi in < 2 yrs we're buying another family car (XV Crosstrek maybe), at which point the STi will likely get a bigger turbo and bigger makeover. We'll be in touch, Mike! :)
-Chris
Umass94 12-16-2012 09:26 AM
Lazy subscribe, I need a tune in January.
BMA44 01-13-2013 10:35 AM
Just Pm'd ya mike!
chimaira4deth 01-21-2013 08:28 PM
i'll be in touch soon.
stage anxious
Tuning Alliance 03-11-2013 06:25 PM
Thanks guys. I'm here to help.
hadvw 04-14-2013 08:08 PM
Just wanted to say, I'm in the process of getting an open source tune with Mike, and he has been responsive, courteous and very knowledgeable about my questions. Very satisfied so far. I needed someone to do this via email, since I don't have time to take a whole day off and drive 3+ hours to get tuned. He has worked with my schedule, and I would not hesitate to recommend him.
