Subaru Legacy Forums
-   Fifth Generation Legacy (2010 - ) (http://legacygt.com/forums/forumdisplay.php?f=92)
-   -   Winter Tire Sizes 2012 LGT (http://legacygt.com/forums/showthread.php?t=193709)
JMules 09-26-2012 02:54 PM
Ok, I posted this in the winter tire thread and haven't gotten a response.
I've done a number of searches and maybe I'm missing it. I see a bunch of reviews of snow tires, but no one seems to mention the size they use. I have a 2012 LGT, looking for snow tires. Tire rack recommends 225/50R17's, but I'm curious as to whether or not we can run 225/45R17's or 55's. Anyone have any experience with those sizes? Thanks!
pfoyle 09-26-2012 04:19 PM
When I got new rims for some summer tires, I wanted to use the stock rims for my winters... Ended up getting 215/45/18s (Blizzak LM-60s, same that Rogue77 got), which although a bit narrower, fit the rims just fine. If you aren't limited to 18" rims, I think you have many more options with 17"s... but I don't know any specifics about other sizes...
minuccims 09-26-2012 04:35 PM
Stay away from 45s for winter. 55s may fill up the wheel wells too much. Snow will fill the wells and not have anywhere to go.
DeltaSniper 09-26-2012 04:50 PM
Went through winter with a 55 series sidewall with a winter autocross session thrown in there. 215/55/17 to be exact.
(Pic Here http://i1054.photobucket.com/albums/...r/IMG_7670.jpg )
If you consider the fact that I was lowered, then I would say a 55 series sidewall wouldnt have any negative side effects in terms of snow buildup.
It is also very close to my 245/40/19 over all diameter for my summer set, which is a very accurate overall diameter for the speedometer.
minuccims 09-26-2012 05:01 PM
Good info
eckseleven 09-26-2012 06:03 PM
I have 215/55/17. I got the tires and wheels from discounttiredirect. I recommend checking them out. Cheaper shipping than tire rack.
pfoyle 09-26-2012 07:26 PM
Out of curiousity, why do you say to stay away from 45s? Too low profile? Problems with potholes? I just got new Blizzaks, so I'm not getting rid of them for a few years, but wondering what the problem is... Thanks!
minuccims 09-26-2012 07:33 PM
on 17", the 45s may be be a harsh ride. My winters are 225/45/R18 and they are Ok on RCE blacks. A little more sidewall would be better.
Tirerack now has 17" steelies. The 215/50s should be a nice ride and others have indicated no problems with 215/55s.
withiam 09-26-2012 07:53 PM
I will be running 215/55-17 winter tires on my 2013 2.5 Premium.
They finally got it right and do not offer the Premium with 16" alloys. The stock 17's will become my winter setup as I already have 18's for the other seasons.
Subie_Mick 09-26-2012 08:06 PM
1 Attachment(s)
I run what Subaru puts on the Limited 17" wheels. 225/50/17 and as you can see I got them on 4th gen wheels. The sizing is perfect relation to the factory 18s.
Blizzard 09-27-2012 06:38 AM
I've been using 215/55-17's for the past 3 years with no issue. Car was always stock ride height though.
http://i32.photobucket.com/albums/d5...rSnow2copy.jpg
Ellesedil 09-27-2012 08:12 AM
Do you use 18's for the summer? Or did you go up?
Blizzard 09-27-2012 09:18 AM
Me? I run the stock 18's in the summer for the moment.
Also just noticed the OP is from WNY. Where are you JMules?
acumenhokie 09-27-2012 10:13 AM
I run OEM size winter tires on the OEM rims but I get a lot less snow down here.
JMules 09-27-2012 10:46 AM
Awesome info, thanks everyone!
