Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Help a noob: banjo bolts and rear struts (http://legacygt.com/forums/showthread.php?t=193667)
gear_monkey 09-25-2012 09:29 PM
Hi all,
Could someone plz show me where the dang passenger side banjo bolt is?? The picture in the walk through thread is not helping me. When I'm looking for it I'm standing by the right front tire looking down at the turbo.
Next thing..how the heck do you get to the tops of the rear struts?? I think I have some loose bolts but don't know how to access them.
Thanks!!
bomberlegacy 09-25-2012 09:35 PM
The top of the rear struts are in the trunk behind the side carpet molding.
Haight 05LGT 09-25-2012 09:35 PM
Banjo bolt is in the Oil feed line below the heatsheild bracket.
Rear struts are in the trunk under the carpeting I believe.
gear_monkey 09-25-2012 10:11 PM
Thanks guys. Unless I'm blind the top of struts aren't behind carpet. I pulled it back and looked. It almost seams that the rear top shelf felt piece and back seats need to be removed. If that is the case, I am beyond my skilz..
Haight 05LGT 09-25-2012 10:24 PM
Wagon or sedan?
Boost_Doc 09-25-2012 10:25 PM
I removed my back seat to access the tops. Seemed a lot easier that way
Max Capacity 09-26-2012 06:01 AM
Which banjo bolt are you looking for the one on the turbo or on the back of the head ?
I guess the 07-09's have one on top of the engine instead of the back of the head. That is the one with the filter in it.
dingbang 09-26-2012 08:07 AM
You have to yank the carpet out from where it tucks in on the backside of the rear seat...pull it back and you'll see the strut tops. In a sedan at least
dingbang 09-26-2012 08:10 AM
If you have a sedan...
http://legacygt.com/forums/showpost....72&postcount=4
Number 32 in the above post.
xt2005bonbon 09-26-2012 08:39 AM
Originally Posted by gear_monkey (Post 4087129)
Hi all,
Check this out: http://legacygt.com/forums/showpost....14&postcount=1
BarManBean 09-26-2012 08:45 AM
Originally Posted by xt2005bonbon (Post 4087483)
This is the best image I've seen yet to show where the banjo bolt is located--I may actually try to check it now...:redface:
gear_monkey 09-26-2012 05:56 PM
Perfect! Thanks!
gear_monkey 09-26-2012 05:57 PM
Very nice! Thanks!
TenzoGT 09-26-2012 06:31 PM
Below the heat shield... Tough to get to without removing the shield.
gear_monkey 09-26-2012 10:03 PM
Ok..after just about killing myself getting into a position inside the trunk to get to the strut mount tops (I'm 6'4"), I removed the rubber plug and attempted to tighten the center bolt that sits below the trunk sheet metal.
To my disappointment it felt like I was just rotating the bolts instead of tightening them. I turned the socket about 3 full swings without feeling any torque increase. This was the same for both sides.
Am I missing something obvious?
