Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Engine Seized (http://legacygt.com/forums/showthread.php?t=193386)
leggyman17 09-20-2012 09:07 PM
Engine Seized
Went to the drag strip last weekend..made 5 passes (best pass was a 13.9) and while sitting,idling in the parking lot after a run my engine shut off..no warning lights, nothing...shut off.
Checked oil level, clean and full
Coolant was good
Removed timing belt cover...not snapped! lol
Couldnt turn engine over manually with socket and ratchet..so made an appointment with a local machine shop to rebuild the engine..
Took the engine out...dropped the oil pan...looks to me like a spun bearing.
But its strange because 1)it happened at idle and 2) the oil was clean and full..
HMM..
Will update when i get word from machince shop..
idiot4hire 09-20-2012 09:31 PM
I want to just get my timing belt done now to prevent this from happing to me
specialB 09-20-2012 09:50 PM
Sorry for your loss
Sent from my DROID RAZR using Tapatalk 2
Max Capacity 09-21-2012 04:54 AM
What oil were you using ?
It's kind of odd that would happen without any prior noise. I'm also sure you were not expecting it so you were not intent on listening to the engine sounds.
Yes, do let us know...
leggyman17 09-21-2012 07:28 AM
Wasnt a timing belt issue..
leggyman17 09-21-2012 07:29 AM
Mobile 1 5w-30 synthetic. Maybe i should use something thicker.
BarManBean 09-21-2012 07:32 AM
Mobile 1 5w-30 is notoriously bad oil for these cars. No real 'science' to back this up, but why use it when there are so many other "better" options. Go with Rotella T6 5w-40, full synthetic. It's cheap and readily available at walmart / advance auto.
Nrw 09-21-2012 07:33 AM
Wonder if it was your oil pickup that cracked
leggyman17 09-21-2012 07:54 AM
Ill have to use that when i get my engine back! i never knew about the mobile 1 being "bad" for our cars
Didnt appear cracked when i removed the oil pan.
xt2005bonbon 09-21-2012 08:25 AM
That's what I was thinking too.
Max Capacity 09-21-2012 08:37 AM
Could this be the first real evidence of why you should not use Mobil1 5w-30 in these engines.
If you still had the oil, you may be able to send it to Blackstone Labs.
Were you on the stock tune ?
leggyman17 09-21-2012 09:01 AM
No, i was runnin an EFI Logics stage 2 tune at the time
Max Capacity 09-21-2012 09:04 AM
Oh so your local, where do you live ?
What track Etown or LVD ?
My car ran 13.86 at LVD back in 05.
leggyman17 09-21-2012 09:16 AM
Yea im from CT. happpend at LVD. 500$ tow bill home.... lol
