Subaru Legacy Forums
-   Fourth Generation Legacy (2005 - 2009) (http://legacygt.com/forums/forumdisplay.php?f=10)
-   -   Legacy SCCA autoX classing question (http://legacygt.com/forums/showthread.php?t=193196)
wawazat 09-17-2012 06:37 PM
Finally got some time to head out and take the Legacy out to the Detroit Region SCCA event this weekend at the Pontiac Silverdome (loooong asphalt courses that are bumpy). I've only autoX'd this car once in the past as I typically take my 5-speed swapped SVX and run in SM but it needs some work which I wont have time to complete before the event.
Mods are simple-larger diameter F+R anti-sway bars with urethane bushings and endlinks as well as 225/45-18 Conti DW tires (non-stocK specB size). From my quick review I see the car in DS and with the changes this takes it to STX. Is this correct?
Thanks!
SCHM1AN 09-18-2012 07:35 AM
Yes, you're correct. I ran DS since my car was completely stock but bumping your wheel size up another inch will automatically set you in STX. For 2012 you're allowed to run front and rear sways, whereas in previous years it was only one or the other.
whitetiger 09-18-2012 08:09 AM
yes, STX is your class.
wawazat 09-18-2012 10:28 AM
Thank you gentlemen
While I don't expect to be competitive I do wish to be classed correctly.:)
BTW-whitetiger I REALLY REALLY want your wheels. They would allow me to mount the Stoptechs currently in my garage.
whitetiger 09-18-2012 10:47 AM
so why dont you buy them ;)
pm me, i make you deal.
Shane86 09-19-2012 04:49 PM
Front OR Rear swaybar, not both in stock class.
In previous years it was JUST the front sway bar you could change.
SCHM1AN 09-19-2012 05:21 PM
Yes, you are correct- thanks for catching that. I just looked up the rules to double check and it says you may use one swaybar in the stock classification. Any bushing material can be used
SCHM1AN 12-06-2012 10:00 AM
If I decide to keep the VF40, but have a BNR16g compressor put in, which class would that throw me in?
StoplightAssassin 12-06-2012 10:07 AM
Street Mod.
