Coils in the winter
Is there anything I should do to my isc coilovers to protect them in the upcoming winter months here in Idaho??
You could probably wax or grease the surface of them. Wash them after driving through salt roads. VWVortex mentions spraying coilovers with clear coat.
Best one yet: KY warming lubricant. IDK. They probably won't last much more than 5 years of normal use anyway. |
Swap them out,unless of course you no longer have the stock stuff.
If you haven't already, anti-seize the shit out of everything, all of the hardware you can, especially the collars and threaded bodies of the coilovers to make sure nothing seizes up.
IIRC you can also get 'coil socks' which fit over the spring part of the coilover and protects the spring and damper from all the nasty parts of winter. |
How long have you had them?
How are they set? Stock prior to these? Love them? So many questions.... |
clean up real good before the roads get crazy and try these out.
http://www.gearheadsonline.ca/shop/p...&cat=60&page=1 |
what's the difference between oil and gas COs? sounds like oil and gas company...
heard that oil COs do not bear winter well |
Best bet for you people with harsh winters is to swap to stock stuff or struts/springs for winter.
If that is not an option, clean them thoroughly, and as said above, anti-sieze, anti-sieze, anti-sieze. Coat everything threaded. Also try to spray the salt off from time to time. |
I'm sure that wouldn't hurt. It will trap more moisture in there though so maybe coat some of the surfaces with grease?
Exactly, anti-seize + cover = win.
Looks like a condom for your coilovers.....use the ky ftw :lol:
I plan on getting the ribbed one so it fits in/on to the threads and springs perfectly.
I would suggest Go back to stock for winter or if not feasible, anti seize and grease the crap out of them.
-Mike Paisan http://www.pbase.com/paisan/image/91072632.jpg http://www.pbase.com/paisan/image/14...8/original.jpg http://www.pbase.com/paisan/image/133406601.jpg http://www.whiteline.com.au/images/logos/perf1.jpg 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
| All times are GMT -6. The time now is 02:14 AM. |
