Subaru Legacy Forums
-   Cars For Sale (http://legacygt.com/forums/forumdisplay.php?f=29)
-   -   (OR): 06 LGT Limited 5EAT 130K chassis Brand new motor (http://legacygt.com/forums/showthread.php?t=192420)
a93x 09-03-2012 04:09 PM
7 Attachment(s)
Year, Make and Model: 2006 Subaru Legacy GT Limited Sedan
Color: Brilliant Silver Metallic
Miles: 135,xxx (as a daily this # will cont. to increase)
Transmission: 5EAT Auto
Title: Clean
Lien: Bank has the title
VIN: 4S3BL676264207598
Seller's email address: pm for email.
Asking Price: PRICE $14,000
2/13/13 UPDATE
Spun a bearing on Cyl.#3. brand new 2005 STi short block is getting put in with a low miles VF-40. Heads are being sent to be resurfaced/machined. Also taking off the Front mount and switching back to Top mount. She is still for sale at the same asking price but with a BRAND NEW MOTOR all installed and worked on by a professional Subie shop. Thanks. More to be updated later.
since buying it I have records for the following
-fixed coolant leak on return line of turbo/flushed coolant w/ new fluid
-DBA4000 rotors, HAWK HPS pads (front) (125K)
-new fluids (redline motor oil) coolant, diff/tranny fluid
-GMS turbo inlet
-Replaced rear wheel bearing - new ABS sensor
-replaced LCA bushings (f/r)
-Whiteline endlinks/polyurethane bushings
-new NGK iridiumIX spark plugs
-replaced front o2 sensor
-new front passenger axle
-compression is good (145 all 4 cylinder)
-pre dyno inspection performed by Cobb Tuning Surgeline
-GM EBCS
-PRE Opensource Dynotune
-Coolant pressurization test
-Smoke test
-Prosport boost gauge
-gates racing timing belt kit / water pump/ t stat
The Goodies
leather+sunroof
Engine
- VF-40 with 70K odo
-Bullet proofed top mount
-GMS turbo inlet
-Cobb catless up pipe
-invidia catless down pipe
-Magnaflow CBE
-Grimmspeed EBCS
-stock injectors
-upgraded fuel pump
-new Ngk iridiumIx plugs
Suspension
-STi pink springs / SpecB bilstein struts
-SS braided brake lines
-STi Brembos / DBA4000 rotors / HAWK HPS pads (front) (125K)
-LGT calipers / oem rotors / Stoptech Street pads (rear)
-18x8 gold wheels
-BRAND NEW tires
-White line end links +bushings (front)
-Gates racing timing belt kit w/ water pump (125K)
Cosmetic
-cleared/blacked lights
-grill delete
-legal tint.(does need to be redone. Small 5in corner on rear quarter window came off)
-waterproof floor mats
-aux cord for Ipod
-Diode Dynamics LED conversion kit
-6K HID low beams
- Plasti dipped scoop / fog bezel / grill
Feel free to email/pm/post on here any question's you got. Thanks for looking!
Picture below is the most recent / up to date one that I have
http://i1271.photobucket.com/albums/...psc4ddb65a.jpg
a93x 09-07-2012 08:12 PM
Friday bump! Great car
Haight 05LGT 09-09-2012 01:31 AM
Bump!
dansbiker 09-09-2012 10:26 AM
nice car.. but the price is way to high!
SBT 09-09-2012 11:12 AM
Need to post up some interior photos.
Pete1122 09-09-2012 04:23 PM
How is the 5EAT holding up to that power?
a93x 09-09-2012 05:08 PM
Someone will take it. I've done 2k in routine maintennence since ownin it. The price isn't just because of all the parts. I know that holds no value.
Need to or should?
Really great! Fmic and new tune are coming this month regardless If I get any bites.
SBT 09-10-2012 07:02 AM
Originally Posted by a93x (Post 4063209)
Need to or should?
Either - it's required? :) Check the CFS sticky for more info.
a93x 09-21-2012 09:11 AM
Friday bump!
Haight 05LGT 09-21-2012 09:43 AM
:spin:Interior pics! NOW!
Saleen S7 TT 09-22-2012 11:04 PM
Nothing done to the transmission at all?
a93x 09-22-2012 11:15 PM
Meeting prev owner on tues and will have all details on build and paperwork. I believe it has the hex mods vb upgrade. I've been told it was on a corn map for 3 years and then detuned and put back to a pump map after owner 1 built it. It's an awesome car no doubt I've been having fun with it.
It's new tune with the Perrin fmic is scheduled for tues/weds right after my meeting at traffic court :D. Ill be sure to post dyno sheet and newest numbers. And also a few interior shots. Thanks.
Haight 05LGT 09-22-2012 11:18 PM
Im calling 323/341.
a93x 09-22-2012 11:24 PM
as what? the numbers after the tune? yea I was guessing the same. With corn Im definitely capable of safely making more. With the forged internals, larger turbo, injectors pump etc. this setup is pretty sweet. Im excited to see how she runs after the tune.
Haight 05LGT 09-23-2012 06:34 AM
Interior pics!
